*Attn. Willis* or anyone else that can help
I've got a couple of questions if you wouldn't mind helping me out. I've got a 92vx with a B16.
1. Do you still have the egr controll box hooked up in your car. From what I understand all I need to hook up is the evap purge cut solanoid and my B16 will pass emissions.
2. Do you have or know where I can find schematics for a P28 ecu to hook up a V-AFC?
Thx.
Thx.
Guest
Posts: n/a
Re: *Attn. Willis* or anyone else that can help (Pressurized)
1. Yes, please hook up all the emissions equipment. The engine will actually run better with it on.
2. APEX provides you with all the instructions necessary to install the VAFC, and they tell you the location and wire colors for specific cars. Your 92 should be in there.
Re: *Attn. Willis* or anyone else that can help (B18C-EJ1)
Thanks for the info. I've got a SAFC from a friend but the instructions aren't vehicle specific. Do you know the wire colors and location on the ecu plugs for the tps, rpm, power, ground, etc.?
thk
12-26-2003 01:43 PM
