**Official H2B Discussion thread **
#301
Re: (Bserious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserious »</TD></TR><TR><TD CLASS="quote">
Very much correct. And all kits ordered were sent out today.
What a bust f'n day. </TD></TR></TABLE>
good for you guys...glad i ordered my **** like in march
#303
Re: (sikciv666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikciv666 »</TD></TR><TR><TD CLASS="quote">
good for you guys...glad i ordered my **** like in march</TD></TR></TABLE>
ordered mine early may and was contacted by seth and refunded $60 for the wait...its a big demand so we gotta be understandive and just wait...nothing else to do lol..
#304
I'm really 2slow
Re: (amy)
this is how it sits as of now
This is the clearance for the crank pulley. Moved in 1/2" and shaved down. Framerail was not modified at all
Clearance for the alternator
Just a side shot of the beast
Front shot
Front shot
#306
I'm really 2slow
Re: (STEV3-O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEV3-O »</TD></TR><TR><TD CLASS="quote">looking sweet, u gonna have it done in time for CMI? That be tight 3 cars, all red, and with H2B </TD></TR></TABLE>It will be done hopefully tomorrow Im pretty much done I need to put in the axles, weld the exhaust and bolt up the linkage ohh and cut the hood skin CMI sounds good
#307
Re: (2FAST4U831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 »</TD></TR><TR><TD CLASS="quote">It will be done hopefully tomorrow Im pretty much done I need to put in the axles, weld the exhaust and bolt up the linkage ohh and cut the hood skin CMI sounds good </TD></TR></TABLE>
Damn thats a tight fit on that crank pulley, thast shaved AND moved in the half inch?
Whats that above the crank pulley, hitting the frame rail?
#308
I'm really 2slow
Re: (4door_demon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon »</TD></TR><TR><TD CLASS="quote">
Damn thats a tight fit on that crank pulley, thast shaved AND moved in the half inch? yes!
thats the tensioner bolt with a **** load of washers It does not hit. It is very very close though
Re: (2FAST4U831)
Sweet, i wish i could get some slicks by then.
#310
I'm really 2slow
Re: (STEV3-O)
Sweet, i wish i could get some slicks by then.</TD></TR></TABLE>street tires will suck
#311
Re: (2FAST4U831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 »</TD></TR><TR><TD CLASS="quote">street tires will suck </TD></TR></TABLE>
Ya i know, im trying to find a dael on used rims and slicks
#312
I'm really 2slow
Re: (STEV3-O)
Ya i know, im trying to find a dael on used rims and slicks </TD></TR></TABLE>what kind of rims are you looking for?
#315
Re: (PhoebeusFenix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoebeusFenix »</TD></TR><TR><TD CLASS="quote">Looks damn good man. I cant believe the pulley is that close to the frame rail. Damnnn. Did you do the balance shaft eliminator kit? </TD></TR></TABLE>
He has the balance shafts still.
Keep in mind the frame rail has not been modified.
#317
Re: (2FAST4U831)
have you driven it yet? Mine was that close and when you drive it it hits the frame rail!
We had to notch the frame rail to give it more clearance
I'd be really worried about that cause it looks even closer than mine sat - keep in mind when you drive the motor is gonna move slightly
#318
Re: (AllMotorRandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy »</TD></TR><TR><TD CLASS="quote">are you supposed to modify the frame rail?
you can do whatever you please. I was just clarifying what he had done.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amy »</TD></TR><TR><TD CLASS="quote">
I'd be really worried about that cause it looks even closer than mine sat - keep in mind when you drive the motor is gonna move slightly </TD></TR></TABLE>
Mine is very close as well, just depends on the mounts how much clearance is required. My hasports are SOLID.
#319
Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">Mine is very close as well, just depends on the mounts how much clearance is required. My hasports are SOLID.</TD></TR></TABLE>
ahhhhhh that's whre you win - you and your hasports
#321
Ditto
Re: (amy)
Get performance mounts
#322
Re: (amy)
ahhhhhh that's whre you win - you and your hasports </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEV3-O »</TD></TR><TR><TD CLASS="quote">my motor dont move a damm bit Hasport race urethane for the win </TD></TR></TABLE>
yep
The hasports are tiite
yep
#324
I'm really 2slow
Re: (amy)
Hasport Xtreme race Dont think it will move. Heck! it didnt even move with just the rear and driver side motor mounts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoebeusFenix »</TD></TR><TR><TD CLASS="quote">Looks damn good man. I cant believe the pulley is that close to the frame rail. Damnnn. Did you do the balance shaft eliminator kit? </TD></TR></TABLE>no eliminator kit. Just took balance shaft gears out
#325
Re: (2FAST4U831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 »</TD></TR><TR><TD CLASS="quote">Hasport Xtreme race Dont think it will move. Heck! it didnt even move with just the rear and driver side motor mounts
no eliminator kit. Just took balance shaft gears out </TD></TR></TABLE>
ok good, damn it i need new mounts
