Honda S2000 Honda S2000
X brace
Old Mar 3, 2003 | 11:48 AM
M-Type's Avatar
Default X brace
Any one have any experience with the spoon or the comptech Xbrace??? Do you feel any difference? Is it true that the comptech x brace give more groud clearence than spoons??
Old Mar 3, 2003 | 03:00 PM
02SpaS2000's Avatar
Default Re: X brace (M-Type)
I have the spoon x-brace. It's winter right now, so I haven't really driven much since I installed it, especially any "spirited" driving. But I do seem to feel rough roads a little more than before, which to me is a sign of more stiffness. I don't know about ground clearence differenced between the 2, but I'm sure it's not much.
Old Mar 3, 2003 | 06:46 PM
M-Type's Avatar
Default Re: X brace (02SpaS2000)
any more?
Old Mar 3, 2003 | 10:18 PM
AJ PwR's Avatar
I have the Spoon X-brace. You will notice much stable at the front when cornering , I feel the front of the car more rigid and much better turn in response.
Old Mar 4, 2003 | 05:43 PM
M-Type's Avatar
Default Re: X brace (AJ PwR)
thanks guys, I was also trying to understand why the spoon cost less than comptech
Old Mar 5, 2003 | 04:11 PM
KF_S2000's Avatar
I can't give you any info on why the Comptech piece costs more than Spoons', but I can give you some input on the changes experienced by install Spoons X Brace.
It seems that the "shock" felt by bumps is handled more by the suspension, instead of making it through the suspension and releasing its energy on the chassis. Thus, going over bumps and uneven road surfaces will feel a little smoother. I've also noticed that steering response at all speeds, high or low, have increased. And it seems that low speed steering effort has been reduced.
Old Mar 6, 2003 | 06:52 AM
Schatten's Avatar
Default Re: X brace (kf_Type-R)
the neuspeeds are also a cheaper alternative. the neuspeed xbraces clear when oil is drained, so you don't get the x-brace oily. not that it would matter, but it does happen.
as for the comptech - its a low profile x-brace, so its tucked up under the car instead of hanging down approximately .5 - 1" from the car.
Old Mar 6, 2003 | 03:48 PM
2K2 S2k's Avatar
I am using the Pro Autosports X-Brace and noticed a definite improvement in steering response. It makes controlling oversteer much easier by allowing you to make quick precise adjustments and sensing the changes immediately. The X-Brace from Pro Autosports is very low profile (Excellent ground clearance) and is made of lightweight aluminum. I highly recomend getting any brand of X-Brace if you are serious about performance. Check out the Pro Autosports X-Brace at:
http://www.proautosportsinc.com
Old Mar 6, 2003 | 04:11 PM
Schatten's Avatar
Default Re: X brace (2K2 S2k)
interesting x-brace. I haven't heard of that one. any of them will give the same benefit and weigh about the same, which is approximately 8.5lbs. (aluminum or steel)
but it doesn't look that low of a profile. the comptech doesn't hang down at all. that's the main advantage of the comptech unit. so if you were to get one of the mugen front spoilers either the full front bumper (big smiley face) or half bumper, with the under tray which fits tightly, you *might* be able to use the comptech piece with it.
Kal
Apr 18, 2004 07:30 PM
minivanman
39
Apr 6, 2004 10:25 PM
nightryder21
Sep 17, 2003 12:23 AM
Flux
Jan 7, 2002 01:01 PM
Unlimited
Nov 27, 2001 06:11 AM
