Honda S2000 Honda S2000
windshield washers no work
Old Jan 18, 2006 | 09:59 AM
gabspeed's Avatar
Default windshield washers no work
hey sup guys just picked up a 04 S2k incredible ride i have just run into a small problem thou, the windshield washers are not working it sounds like if it didn't have water but its toped of what would it be ?? how can i check the tank (its inside the fender!!) thanks
Old Jan 18, 2006 | 10:03 AM
bryant's Avatar
Default Re: windshield washers no work (gabspeed)
I think you just answered you own question. Take the fender off.
Also check the lines see if they are clocked. Does it sound like its working when you hit the switch. Maybe you blew a fuse.
Old Jan 18, 2006 | 04:14 PM
Mr. Projekt's Avatar
* B A N N E D *
The fill cap is next to the battery. Check the wiring (2pin plug), fuse.
Old Jan 18, 2006 | 04:17 PM
revhi's Avatar
Iff the tank is full, poor some warm water on the nozzles or use a pin.
Old Jan 18, 2006 | 04:40 PM
* B A N N E D *
Default Re: (revhi)
^^ True. I've gotten some wax in the spray nozzles and clogged it once.
Old Jan 18, 2006 | 09:09 PM
MAD ITR 55's Avatar
Default Re: (Slideways2000)
When I first got my car my passenger side one didn't work and it was some wax or something clogging the nozzle. Just take out your nozzles and blow air through them or use some sort of parts cleaner.
Old Jan 19, 2006 | 04:56 AM
Nishant's Avatar
Default Re: (MAD ITR 55)
First step - When you try to use the washer nozzles, do you hear the motor working. If no, its your motor, fuse, or some wiring issue. If yes, then see next step.
Second - If you hear the motor working, first check to see if the nozzles are clogged. This is usually the culprit. If it still does not work, you may have a pinched line. It is located inside the fender but is accessible if you remove the fender liner.
Old Jan 19, 2006 | 07:09 AM
gabspeed's Avatar
Default Re: (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">First step - When you try to use the washer nozzles, do you hear the motor working. If no, its your motor, fuse, or some wiring issue. If yes, then see next step.
Second - If you hear the motor working, first check to see if the nozzles are clogged. This is usually the culprit. If it still does not work, you may have a pinched line. It is located inside the fender but is accessible if you remove the fender liner.</TD></TR></TABLE>
yes the motor works, cleaned the nozzels worked perfectly ones then it doesn't work anymore seems like if it didn't have enogh pressure or something weird. spits a little bit but thats it
Old Jan 21, 2006 | 03:03 PM
preludexl's Avatar
Default Re: (gabspeed)
i have the same problem with my 04. i used my basketball pump and blew air into it...the hose from behind the hood....not through the nozzles. it got plugged again by itself somehow.
Old Jan 21, 2006 | 04:39 PM
SuzukaBlueAP2's Avatar
Default Re: (preludexl)
My washer tank still has the OE fluid in it from the factory. I don't use them on my 04.
Old Jan 21, 2006 | 04:45 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabspeed &raquo;</TD></TR><TR><TD CLASS="quote">
yes the motor works, cleaned the nozzels worked perfectly ones then it doesn't work anymore seems like if it didn't have enogh pressure or something weird. spits a little bit but thats it </TD></TR></TABLE>
my guess is your line is pinched somewhere. if you find the line is not pinched, then something may be wrong with the motor.
Old Jan 22, 2006 | 09:28 AM
2000S2000Mike's Avatar
Isn't your S2k still under warranty?
Old Jan 23, 2006 | 05:09 AM
gabspeed's Avatar
Default Re: windshield washers no work (2000S2000Mike)
yes it is in warranty but they are working now i guess it had air on the lines thanks for the help
khronicboy420
Sep 1, 2009 10:26 AM
MagnaniEG6
11
Feb 24, 2007 11:16 PM
DA is best
Aug 28, 2006 09:37 AM
CrXbOi
Dec 30, 2003 11:19 AM
