Honda S2000 Honda S2000
window alignment
Old Jul 7, 2008 | 07:28 AM
dartonh22's Avatar
Default window alignment
i have an oo with the oo plastic rear window and top, and it doesnt fit very well, for one when i close the top i have to pull it down and over to the left to latch it, but my problem is the gap between the drivers side window and the convertible top, when im driving it makes a terrible whistling noise and i wanted to know if the window can be shimmed or the top can be adjusted, its my first convertble and i dont know if this is a normal thing or not.
Old Jul 7, 2008 | 07:38 AM
dartonh22's Avatar
Default Re: window alignment (dartonh22)
Modified by dartonh22 at 9:15 AM 7/12/2008
Old Jul 7, 2008 | 07:58 PM
NFRap1's Avatar
has the top been modified at all?...as in the speed sensor wire on the conv. top brain removed?...maybe it was opened at a high speed and it bent the frame?
Old Jul 7, 2008 | 08:00 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
remove your door panel and plastic liner, there are 3 bolts and there are "adjustment slots in which they lay in. adjust the window this way. loosen them and adjust accordingly untill you get it just right with the top.
also help to coat/treat your top and winshield strippings. Honda sells the lube for the S2K its some japanese cream.
Frank ( knowledge ) and GAY- Fiti like to exchange Japanese Male cream
Old Jul 8, 2008 | 04:25 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: window alignment (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">remove your door panel and plastic liner, there are 3 bolts and there are "adjustment slots in which they lay in. adjust the window this way. loosen them and adjust accordingly untill you get it just right with the top.
nice write up...
and yeha they do... butt loving homos...
Old Jul 8, 2008 | 05:47 AM
dartonh22's Avatar
Default Re: window alignment (S2KILLA)
sweet dude, thanks for that i thought i heard somewhere that you can adjust the window but i dont have a repair manual to look it up thanks ill do that today.
Old Jul 8, 2008 | 02:28 PM
dartonh22's Avatar
i tried adjusting the window, it moves up and down but not in and out: which picture above shows the bolts you loosen to adjust, i messed with all of them but couldnt get it right.
Old Jul 9, 2008 | 07:30 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
chek to see how worn out your strikers are, might not be pulling it enough as well
Old Jul 10, 2008 | 04:22 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">chek to see how worn out your strikers are, might not be pulling it enough as well</TD></TR></TABLE>
cant u adjust them as well???
Old Jul 10, 2008 | 05:52 AM
dartonh22's Avatar
im not sure how to tell if they're worn, but the convertible top: lines up with the front window it just seems as though the rear part of the drivers side window sticks out too far, or the conv top is in too much.
Jessgut89
Oct 21, 2015 07:46 PM
JDMgunmetalCRX
Mar 31, 2009 08:50 AM
bopbop93030
Nov 20, 2008 09:03 AM
SlammedHatch90
Jan 31, 2003 03:49 PM
gsrhunny
Oct 2, 2002 11:23 AM
