Honda S2000 Honda S2000
Weird starting problem.
Old Mar 24, 2009 | 08:24 PM
veilsides2000's Avatar
Default Weird starting problem.
Okay so I changed my starter out and now the car will randomly start and then it won't Other times it will only start in gear and then I have to wait some minutes before it does again.
The starter clicks fine and the arm tries to start the car. But it will just click. The battery is brand new and so is the starter and the alternator. But the connection in the back of the alternator (the one with the metal ring is a little loose. Could that be the culprit. I mean I messed around with it and wiggled it and then the car will start fine but right after that it won't.
I have no idea where to even start. Any insight would be greatly appreciated.
Old Mar 24, 2009 | 08:34 PM
RedNuckles9's Avatar
New User
Default Re: Weird starting problem.
i would definately start by making sure you have good ground to everything you've replaced mainly the batt. bad or loose grounds have done this to me and others
Old Mar 24, 2009 | 09:41 PM
Checked them . Still the same problem
Old Mar 25, 2009 | 09:39 AM
Anyone?
Old Mar 25, 2009 | 12:08 PM
bigmacnfries's Avatar
sounds alternator related for sure (unless the battery is underpowered)
Old Mar 26, 2009 | 09:28 PM
The alternator is brand new and all the connections are securely fastened. Battery is brand new as well. I ordered another starter so lets se eif that fixes the problem. Anybody else with some insight?
Old Mar 26, 2009 | 10:57 PM
Eggsix's Avatar
hmmm did you complete this procedure between 59 and 100 degrees F? did you reset the engine controle mudule? what year is your car?
Old Mar 27, 2009 | 05:42 AM
White Smoke's Avatar
i my honda
Global Mod
I have a feeling it's that "lose connection" to the starter, or the starter itself.
Old Mar 28, 2009 | 03:11 PM
Im in florida so it would around that temperature. I did it at night time. (don't know what that has to do with it) \
Engine control module? I took off the negative terminal on the battery. Guess things got reset with that?
Old Mar 28, 2009 | 09:26 PM
S2kVenom's Avatar
That really is weird
Old Mar 29, 2009 | 12:17 AM
b20integrapower's Avatar
there is a ground on the starter itself. This usually is the problem for a "one click" deal. If it goes "click click click" a bunch of times, then it might not be getting enough juice.
Old Mar 29, 2009 | 07:29 PM
Mik's Avatar
Mik
I'd suggest that you get a voltmeter and measure the voltage AT THE STARTER as someone tries to start it (use clip leads and stand away). Should be around 11.5 volts, possibly a bit lower with the starter load. Measure at the battery as well. There shouldn't be much difference in voltage.
Mike
Old Mar 31, 2009 | 01:53 PM
Yeah I just got a used OEM one in from a guy I know. Lets see how that goes. But it won't make a difference in my life right now because MY SEATS GOT STOLEN YESTERDAY!
GAHHHHHHHH!!
Old Apr 1, 2009 | 05:17 AM
i my honda
Global Mod
Dam man that really sucks!
syvpunk
Oct 17, 2010 08:14 AM
EGHondalover88
31
Jan 18, 2010 03:26 PM
DC2_ALL MOTA
Oct 10, 2006 01:31 PM
VisPreludeVtec
Dec 9, 2004 09:44 AM
wambus
Feb 27, 2004 07:58 AM
