Honda S2000 Honda S2000
valve tick?
Old Feb 22, 2007 | 08:03 AM
b20integrapower's Avatar
Default valve tick?
ive noticed recently that my motor has been making a "clack" noise. its not rod knock..and its pretty quiet. i was thinking maybe it was the valves. are there any parts of the s that are notorious for making unwanted noise but are rather simple fixes? ty guys
Old Feb 22, 2007 | 08:04 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: valve tick? (b20integrapower)
Sorry man I would guess, but there's so many choices to guess, so I say let me listen to it first.
Old Feb 22, 2007 | 08:13 AM
dcturbols's Avatar
Default Re: valve tick? (Mr. Projekt)
I just noticed the same thing last night.
For me it sounds like popcorn popping in a microwave but very faint.
Old Feb 22, 2007 | 08:25 AM
* B A N N E D *
Default Re: valve tick? (dcturbols)
Put your ear near the valve cover and listen for taps? Low on oil? Heatshield rattling?
Old Feb 22, 2007 | 09:49 AM
its not a rattle...it definately sounds engine related...nothing on the exterior of the engine. ill try to get a sound clip for u guys today. gotta wait for my gf to get off school so i can use her camera
Old Feb 22, 2007 | 09:55 AM
* B A N N E D *
Where it's coming from is important too. Did you actually listen under the hood or did you hear the noise sitting in the cabin?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">are there any parts of the s that are notorious for making unwanted noise but are rather simple fixes? ty guys </TD></TR></TABLE>
Old Feb 22, 2007 | 01:18 PM
under the hood. sounds like its coming from the motor. u can barely here it when ur in the cabin. ill just get a video soon. then we can all have something to talk about.
Old Feb 22, 2007 | 01:35 PM
18psi sohc's Avatar
How many miles does your S have.. You're supposed to have your vavle clearance inspected about every 75k miles. Check if it goes away wen you step on the clutch. If it does then you just need to service your clutch. If not it might be the valve clearance or the belt tensioner pulley that needs some lube.
Old Feb 22, 2007 | 04:12 PM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
i think you will need a valve adjustment depending on how many miles you have on the motor
Old Feb 22, 2007 | 04:16 PM
iam7head's Avatar
Default Re: valve tick? (18psi sohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18psi sohc &raquo;</TD></TR><TR><TD CLASS="quote">How many miles does your S have.. You're supposed to have your vavle clearance inspected about every 75k miles. Check if it goes away wen you step on the clutch. If it does then you just need to service your clutch. If not it might be the valve clearance or the belt tensioner pulley that needs some lube.</TD></TR></TABLE>
no, manual said 105k, but 14 out of 16 of mine needed adjustment at 90k
since i am doing it myself i check it every 10k, plus you can spot a broken retainer before it's toast you motor
Old Feb 22, 2007 | 05:03 PM
18psi sohc's Avatar
Default Re: valve tick? (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
since i am doing it myself i check it every 10k, plus you can spot a broken retainer before it's toast you motor</TD></TR></TABLE>
Yea i dont think honda thought we were going to be taking it to 9k so often tho.
Old Feb 22, 2007 | 06:03 PM
iam7head's Avatar
Yea i dont think honda thought we were going to be taking it to 9k so often tho. </TD></TR></TABLE>
I am not taking it to anywhere, i diy everything
Old Feb 22, 2007 | 08:01 PM
see..i was thinking it was teh belt tensioner pulley. it was coming from around there. i just wasnt sure if it could make the sound im describing. and my car has 31k on it. still need to get that video clip. gotta get my gf's camera. thx guys!
Old Feb 22, 2007 | 08:30 PM
* B A N N E D *
Belt tensioner/idler shouldn't be out at 31k yet, I hope.
Old Feb 22, 2007 | 09:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Belt tensioner/idler shouldn't be out at 31k yet, I hope.</TD></TR></TABLE>
well he mentioned that it may just need lube. im just gunna shut up till i get that video..then we can have a nice debate with something to back up the claims.
Old Feb 22, 2007 | 10:32 PM
RCautoworks's Avatar
Loud injectors ?
Old Feb 24, 2007 | 01:23 PM
crashedacar's Avatar
Default Re: valve tick? (RCautoworks)
When was the last time the oil was changed? And or low on oil? Is what normally is the problem, but like every one else says you got to hear it before you can diagnose it. good luck!
Old Feb 25, 2007 | 02:42 PM
18psi sohc's Avatar
Watch the tensioner, see if the sound happens when the tensioner pulley moves. Try reving the engine from the throttle body and that should make the pulley move back n forth a little
joshmak
Jun 13, 2010 10:07 AM
kornkid21792
Feb 18, 2010 09:31 PM
sector001
Oct 13, 2006 12:09 PM
ludenutz
Aug 20, 2003 07:30 AM
BryanS
Sep 25, 2001 10:46 AM
