Honda S2000 Honda S2000
Valve Cover Replacement
Old Oct 31, 2007 | 06:30 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Valve Cover Replacement
I did a search and nothing... I just had my spare Valve Cover Powder Coated and was looking to finally install it... I already bought a kit for the seals and the grommets so im set with the installation, just wanted to make sure I had everything, how much to torque down the bolts, and anything else to look out for/tips.
these are the seals i bought:
http://www.hondaautomotivepart...COVER
I purchased #1 and 4 #4's... everything else Im taking off my current valve cover and reusing
Old Oct 31, 2007 | 08:12 AM
S2KILLA's Avatar
Default Re: Valve Cover Replacement (S2KILLA)
bump... anyone?
Old Oct 31, 2007 | 10:15 AM
b20integrapower's Avatar
people may bust me for this, but when i reinstalled my vc i just did it by hand. You kinda get the feel for it. Just look out for overtightening.
I know in B series its easy to over torque and strip the nuts.
Bump for some specifics though
Old Oct 31, 2007 | 11:50 AM
Black S2K's Avatar
When I took my valve cover off for fun I just put it back on the exact same way it came off. And I tightend everything by hand. It looks like you got the right seals. The only thing I remeber being a bitch was getting the back of the valvecover out cause theres this wire harness in the way. But I just kinda squeezed it out and then back on. Anyways goodluck. How much would you sell your extra valve cover for and the gold spark plug cover if you were going to sell them???
Old Oct 31, 2007 | 11:52 AM
papa5murf's Avatar
Default Re: Valve Cover Replacement (b20integrapower)
Click here
Old Oct 31, 2007 | 12:33 PM
140sx's Avatar
imo there is no reason to look that up. youll know when its tight. there is know reason to get to tight on it anyway.
Old Oct 31, 2007 | 12:48 PM
papa5murf's Avatar
Default Re: (140sx)
If you can get the proper torque specs you should do it (on everything). My reason why?...
1. If you don't tighten it enough it can cause failure (eventually) in the form of it backing out, or having a leak and so on.
2. If you over tighten it, it could cause more wear in that particular area and could cause premature failure. On the bolt or the area around it. Not to mention it might become a pain in the *** to take it out if you ever needed to remove that bolt to change a part or something.
Old Oct 31, 2007 | 03:54 PM
140sx's Avatar
Default Re: (papa5murf)
well since a valve cover is in no position to hurt anything other then to leak. that is not something i can see my self takeing the to look up. rod bolts, hg, ect. critcal **** is a differant story.
Old Oct 31, 2007 | 04:07 PM
jefferyg32's Avatar
Default Re: (140sx)
10mm headed bolts torque to 9ft lbs
Use a light coat of oil on the gasket as it will help keep it in the groove.
The only thing to watch for is make sure the tube seals seal around the tubes that the spark plugs go into. Its tricky. Set the cover on then look throught the spark plug holes and you will see the seals. Us a small flat head and be sure not to rip the gasket and slowly work your way around each hole. Use some oil to lubricate it makes it easier.
Old Oct 31, 2007 | 05:35 PM
S2KILLA's Avatar
Default Re: (jefferyg32)
awesome... thanks for the replys... im going to tackle that bitch right now... is there a specific pattern i should follow?
Old Nov 1, 2007 | 11:45 AM
JDMsam.'s Avatar
Default Re: (S2KILLA)
your tightening it either way so in the end it shouldn't make a difference.
Old Nov 1, 2007 | 12:01 PM
S2KILLA's Avatar
Default Re: (JDMsam.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMsam. &raquo;</TD></TR><TR><TD CLASS="quote">your tightening it either way so in the end it shouldn't make a difference.</TD></TR></TABLE>
hmmmmm... somehow im not gonna listen to you... so u just tighten ur lug nuts in a circular pattern? and i guess you tighten your oil pan bolts in any which way? i mena its just gonna be tight right??? :BANGHEAD:
soooo if someone has a real answer please comment... if ur just talking out ur ***... please keep it to yourself
Old Nov 1, 2007 | 12:49 PM
140sx's Avatar
the problem is that is is a ******* valve cover, snug them all up then go over it with torque wrench. very simple ****.
Old Nov 1, 2007 | 12:53 PM
jefferyg32's Avatar
Default Re: (140sx)
Their right. Its only 9ft lbs so any pattern would work. But do like i do on anything like that. Start on the inside and work your way out in a criss cross pattern if you can.
Old Nov 1, 2007 | 01:07 PM
Black S2K's Avatar
yo S2KILLA you better post some pics
Old Nov 1, 2007 | 04:39 PM
S2KILLA's Avatar
Default Re: (Black S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">yo S2KILLA you better post some pics</TD></TR></TABLE>
i will, except one of the seals ripped while installing... arrrghh... so its gonna have to wait another day... ohh and ill give you a hint... it matches my rims...
Old Nov 1, 2007 | 07:42 PM
Black S2K's Avatar
^^ Sick
I was thinking of going that route. But Im going to paint mines black and have the gold ap2 spark plug cover I think that would look pretty good.
Old Nov 2, 2007 | 04:30 AM
S2KILLA's Avatar
ohhhhh def... i was contemplating either way, go with a gold/black theme or go with a black/gold theme...
The intake manifold and throttle body is most likely next. I gotta wait until I get back the bored TB and port matched IM though...
Old Nov 4, 2007 | 10:31 AM
Black S2K's Avatar
dooooooooooooood pics?????
Liquid Trenz
Paint and Body
10
Feb 11, 2011 02:11 PM
ITR32
Jul 27, 2007 06:09 AM
MISFITofMAGIC
Dec 25, 2005 10:21 AM
nerdish
Jul 21, 2001 08:52 AM
