Honda S2000 Honda S2000
VAFC Problem
Old Sep 18, 2005 | 05:27 AM
spooniq's Avatar
Default VAFC Problem
I just installed a VAFC 2. My car wont pass 6,000 RPMs and the engine light is on. And it does that on and off. It would be fine for a little bit and then it willl come back. what shoudl i do?
Old Sep 18, 2005 | 09:00 AM
revhi's Avatar
Did yo use the plug and play harness? If so did you solder the wires? Im betting the CEL is for P1259 VTEC malfunction, your hitting the soft rev limiter. Check the connections.
Old Sep 18, 2005 | 03:07 PM
papa5murf's Avatar
Default Re: (revhi)
also check on your vafc settings... the settings need to be correct in order for it to operate properly...
Old Sep 20, 2005 | 09:32 AM
Saruchan's Avatar
Default Re: VAFC Problem (spooniq)
Had mine on for months without any problems whatsoever. Make sure you double and triple check your wiring connections including the pins that you used on the ECU.
Since the V-AFCs are for Hondas only, the initial settings will be basically preset for all Hondas, ie. 6in 6out, throttle up, and 4 cyl. So unless you bought one used that was messed with or had someone else play with the initial setup, you should be okay on the initial settings. BUT, you should double check it in the etc. menu anyways to be sure that everything looks honky dory.
Also keep in mind that you DONT need to use the Blue VTM wire on the S2000s. On most all other Hondas without that wire you will get the same reaction from the cars, but with the S, you won't have to use that wire and will be able to use the controller just fine. So you might want to double check to make sure that wire isn't hooked into the harness.
Good luck. Hope you will be able to start tunin' it soon.
Old Sep 20, 2005 | 01:35 PM
papa5murf's Avatar
Default Re: VAFC Problem (Saruchan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saruchan &raquo;</TD></TR><TR><TD CLASS="quote">Had mine on for months without any problems whatsoever. Make sure you double and triple check your wiring connections including the pins that you used on the ECU.
Good luck. Hope you will be able to start tunin' it soon. </TD></TR></TABLE>
not completely true... he's got a vafc II.. not the first vafc..... the vafc II, has 3 different settings for vtec, it also has a feature for I-vtec.... the settings on the vafc II will be a little different from the vafc I.... it's more precise...
Old Sep 20, 2005 | 09:03 PM
batmang yO!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saruchan &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you double and triple check your wiring connections including the pins that you used on the ECU. </TD></TR></TABLE>
^^ What Saruchan said! double check it then double check it!
I had a very similar problem with my GSR, turns out it was nothing more than bad wiring. And luckly it was an easy fix.
Old Sep 21, 2005 | 04:04 PM
User Name's Avatar
Easy fix is Frog harnes.....
walo
Dec 16, 2009 02:32 PM
kanye
Jul 2, 2007 01:13 PM
Nisif
Jan 10, 2005 07:06 PM
JakeB.
May 17, 2004 06:22 AM
JakeB.
May 16, 2004 09:03 AM
