Honda S2000 Honda S2000
Toda A's
Old Aug 11, 2004 | 09:14 AM
95dc2's Avatar
Default Toda A's
anyone know what power & torque to expect with this. otherwise stock internals...i understand results may very, just trying to get a general idea TIA
Old Aug 11, 2004 | 09:27 AM
neo1z's Avatar
Default Re: Toda A's (95dc2)
Id also be interested in knowing.
Old Aug 11, 2004 | 11:01 AM
95dc2's Avatar
anyone remember ALLMOTORPACMAN's dyno numbers from one of the sickest s2 ever??? ---hp/---tq
Old Aug 11, 2004 | 06:17 PM
R S2 G's Avatar
he didn't have cams, he just had ems, itb and hytech headers and exhaust and i dont recall him posting up dyno numbers in here or anything of hte sort. oh yea, and 4.77's.
Old Aug 11, 2004 | 07:19 PM
ImportSport's Avatar
There has been alot of talk regarding the toda cam's over at s2ki.com some people have had luck right out of the box. However, a few people have had huge headaches getting gains from the cams and acutally saw losses on the initial install.
I would do a search over there and read up it would seem that unless you are ready to tune and re-tune it would be a somewhat risky addition.
Old Aug 11, 2004 | 08:08 PM
R S2 G's Avatar
Default Re: (ImportSport)
thats what i have heard
Old Aug 11, 2004 | 11:42 PM
evil vapor's Avatar
why are you looking at cams?
Old Aug 12, 2004 | 05:23 PM
95dc2's Avatar
Default Re: Toda A's (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">why are you looking at cams? </TD></TR></TABLE>
Old Aug 12, 2004 | 09:48 PM
AJ PwR's Avatar
It will need some tuning to get these cams to make power. I have seen someone who's running the TODA As with e-manage making additional 11whp which I think not too bad from a stock head and bottom end.
Old Aug 13, 2004 | 12:18 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE> a doesn't answer my question
Old Aug 13, 2004 | 10:51 AM
papa5murf's Avatar
on the toda website they recomend you use toda camshafts with the cams....
Old Aug 13, 2004 | 11:12 AM
neo1z's Avatar
Default Re: Toda A's (03s2kblue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">on the toda website they recomend you use toda camshafts with the cams.... </TD></TR></TABLE>
Um. Camshafts are cams. So this is confusing. Do you mean cam gears?
Old Aug 13, 2004 | 11:15 AM
SimbaDogg's Avatar
wow...they recommend that you use toda camshafts...w/ the toda camshafts? before anyone blasts you for this, i suggest re-wording that.
Old Aug 13, 2004 | 01:17 PM
R S2 G's Avatar
Default Re: Toda A's (SimbaDogg)
now thats some funny ****.
Old Aug 14, 2004 | 07:16 PM
papa5murf's Avatar
Default Re: Toda A's (R S2 G)
blah.... yeah thats what i meant....
Old Aug 15, 2004 | 08:39 AM
CLOUT's Avatar
http://forums.s2ki.com/forums/...68603
Old Aug 15, 2004 | 02:27 PM
J'sRacing's Avatar
http://www.todaracing.com has all specs for the A spec cams
Old Aug 15, 2004 | 02:30 PM
R S2 G's Avatar
Default Re: Toda A's (xmugenx)
sorry but did the s2k in the s2k forum that dynoed have i/h/e vafc? or was it the "claims of toda" that had the parts on their s2k? but anyways, if it was only a 5 hp gain, do you guys really think its worth it? i doubt the 5 hp will even make a 2 tenths of a diff. on the car. am i wrong? i mean its an 1100 dollar cam, might as well save an extra G lets say and buy itb's and get about 30+ whp.
Old Aug 16, 2004 | 12:41 AM
baonest's Avatar
when u get itbs u still need to afford injectors, ems and tuning..
camshafts are an underrated upgrade for the s2k
Old Aug 16, 2004 | 02:17 AM
evil vapor's Avatar
Default Re: Toda A's (baonest)
too much misinformation being spread. $1100 is only for the camshafts, you'll need the valve springs and labor to have them installed with the cams. The cams will shine when the package is completed with a modified cylinder head, increased compression, and with ITBs. ITB's do not = +30whp by themselves. A full ITB setup will run near $3000. and You'll only see the benefits of running one with a EMS + H/E + Tuning that will take many hours. Put a plenum on the ITB's and you'll negate whatever gains you'll get from running them. But maybe running no air filters on a street driven car is okay?
NA isn't cheap, it's expensive. To make it work, you need the whole package. It's not like a SC kit where you can install the bare kit without EMS and make power.
Old Aug 16, 2004 | 08:11 AM
CLOUT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">too much misinformation being spread. $1100 is only for the camshafts, you'll need the valve springs and labor to have them installed with the cams. The cams will shine when the package is completed with a modified cylinder head, increased compression, and with ITBs. ITB's do not = +30whp by themselves. A full ITB setup will run near $3000. and You'll only see the benefits of running one with a EMS + H/E + Tuning that will take many hours. Put a plenum on the ITB's and you'll negate whatever gains you'll get from running them. But maybe running no air filters on a street driven car is okay?
NA isn't cheap, it's expensive. To make it work, you need the whole package. It's not like a SC kit where you can install the bare kit without EMS and make power. </TD></TR></TABLE>
there is your answer.
i think the best mod listed above is EMS(to get first) as vapor has posted many a times, tuning is key and is worth the 1200+dyno time.
Old Aug 16, 2004 | 02:35 PM
R S2 G's Avatar
what is plenum? the filters for the tb's?
XxNeeGrowDxX
Nov 1, 2004 07:17 PM
Atlas
May 21, 2004 09:16 PM
GreenR
Jul 9, 2003 08:46 PM
Rdriven
Jul 7, 2002 11:06 PM
