Honda S2000 Honda S2000
are these wheels a problem?
Old Oct 31, 2007 | 06:47 AM
ap1kindaguy's Avatar
Default are these wheels a problem?
i just bought some wheels for my s2k. i got them off of a friend of mine that has a 04 Si. and the rear wheels are not as wide as my stock ones by just a little bit. is that gonna cause a problem?
Old Oct 31, 2007 | 07:22 AM
LAS2K's Avatar
Default Re: are these wheels a problem? (ap1kindaguy)
not unless you don't like traction at all
Old Oct 31, 2007 | 07:24 AM
Import_Fan's Avatar
You should never go with wheels that are narrower than stock. I'm guessing (almost certain) that they also don't have any stagger. You can run em, but it probably isnt a good idea
Old Oct 31, 2007 | 08:03 AM
Black S2K's Avatar
^^^^^X2
The stock s2k wheels are staggered both ap1 and ap2. So why would you want to downgrade from stock?? I would sell them and get a decnt set that are actually staggered.
Old Oct 31, 2007 | 01:16 PM
S2SLOW's Avatar
Default Re: (Black S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^X2
The stock s2k wheels are staggered both ap1 and ap2. So why would you want to downgrade from stock?? I would sell them and get a decnt set that are actually staggered.</TD></TR></TABLE>
Civic wheels are no the way to go, and you do not have to run staggered wheels, especially if you want to track the car, run the same size all around. The wider the tire is on the front the better the car will turn in the corners......
Old Oct 31, 2007 | 03:53 PM
silentdancer's Avatar
give them back, arent they like 6.5 inches wide
Old Oct 31, 2007 | 05:56 PM
marks_lude's Avatar
Default Re: (S2SLOW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2SLOW &raquo;</TD></TR><TR><TD CLASS="quote">
Civic wheels are no the way to go, and you do not have to run staggered wheels, especially if you want to track the car, run the same size all around. The wider the tire is on the front the better the car will turn in the corners...... </TD></TR></TABLE>
or oversteer ap1's already oversteer too much.
Old Oct 31, 2007 | 08:19 PM
LAS2K's Avatar
Default Re: (marks_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marks_lude &raquo;</TD></TR><TR><TD CLASS="quote">
or oversteer ap1's already oversteer too much.</TD></TR></TABLE>
tell me about it
Old Oct 31, 2007 | 09:34 PM
bky's Avatar
bky
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2SLOW &raquo;</TD></TR><TR><TD CLASS="quote">Civic wheels are no the way to go, and you do not have to run staggered wheels, especially if you want to track the car, run the same size all around. The wider the tire is on the front the better the car will turn in the corners...... </TD></TR></TABLE>
Quite possibly the most deadly advice I've ever seen on HT.
That advice might make sense for a Civic, but not on an S2000.
I ran a non-staggered setup *once* with 225 R-comps on a race track, and the car tried to kill me for it. I'll *never* do that again with a stock suspension (or *ever*, really).
Old Oct 31, 2007 | 10:25 PM
velocityracer's Avatar
Default Re: (bky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bky &raquo;</TD></TR><TR><TD CLASS="quote">
i dont know about that......Most or even all s2k time attack cars and track cars run Non-staggered setups......not 225 though mostly 255 all around......handles great, though they have Great Suspension setups and proper setup for it fenders, etc.
Old Nov 1, 2007 | 05:56 AM
S2SLOW's Avatar
Default Re: (bky)
It makes perfect sense son do some research I've been tracking my car for 4 years with 255 RA1's all around.... And 225 is a tire for a civic.....
Old Nov 1, 2007 | 04:15 PM
mister x's Avatar
^You have the skill and experience to do it, most guys don't, especially the OP. To even consider such a narrow tire and rim combo all around is indicative of his level of expertise. Let's err on the side of caution.
Old Nov 1, 2007 | 05:11 PM
Techno Tonis's Avatar
It makes perfect sense son do some research I've been tracking my car for 4 years with 255 RA1's all around.... And 225 is a tire for a civic.....</TD></TR></TABLE>
stock ap1 rears are 225's.
stock civic tires are like 195's, right?
Old Nov 2, 2007 | 06:22 AM
bky's Avatar
bky
Running unstaggered sizes on the stock suspension is very dangerous.
The only guys I know who track their S2000 with even sizes had front spring rates above 500 lbs/in and front sway bars with at least double the stiffness of the stock bar.
Unstaggered sizes for the S2000 is should not be advised so casually. You really need to know what your doing to your suspension for this, and anyone seeking advice on Civic wheels on an S2000 doesn't need to know about going unstaggered.
Old Nov 5, 2007 | 04:34 AM
S2SLOW's Avatar
Default Re: (Techno Tonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techno Tonis &raquo;</TD></TR><TR><TD CLASS="quote">
stock civic tires are like 195's, right?</TD></TR></TABLE>
The 225 rears are actually 245's
shattered3559
Honda S2000
Aug 6, 2007 06:16 PM
jbell
Aug 21, 2006 03:09 PM
PM-Performance
Jun 7, 2004 07:16 AM
