Honda S2000 Honda S2000
SYSTEM
Old Feb 2, 2004 | 02:30 PM
pearlws's Avatar
Default SYSTEM
im thinking about putting a subwoofer in my s2k. how many inch and should i get 1 or 2 subs? and how much watts should i get for the AMPS?
Old Feb 2, 2004 | 03:15 PM
S2KandSTi's Avatar
Default Re: SYSTEM (pearlws)
All you'll need is a 1 good 10", or a great 8". I'd recommend at least 300W RMS for the 10" and probably the same or more for the 8". If you are into Trunk shaking bass, you can fit 2 10's in the trunk, or a 12. Search S2Ki.com for lots more info.
Old Feb 3, 2004 | 05:03 PM
JonV3's Avatar
I have a friend that put two 12s in his and it sounded great, however he had alot of problems with his top vibrating on the highway. All you need is a good ten with a 350w amp. I would go with a ten its more practical. Too bad he wrecked it, Grand Prix white Special edition Pace Car with at least 12 signatures from NASCAR drivers, DUMB *** I know!!!
Old Feb 4, 2004 | 08:59 AM
ak-s2000's Avatar
Default Re: SYSTEM (JonV3)
I had a system with 4-8" on a SoundStream A100 (long time ago) and A50 front and A50 rear running MB Quart and it rocked and also won numerous competitions. My point, you do not need a 300-350 watt amp. for a sub. Get a C.V. 8" good 100 watt amp. and get a second for the mid range or get a 4 channel amp to run everything.
SLIKKCHICK
May 17, 2006 02:22 PM
TheSpoonSwan
Audio / Security / Video
Feb 5, 2006 12:59 PM
ilikemyaccord
10
Nov 17, 2002 11:40 AM
CRXican
Mar 26, 2002 01:44 PM
