Honda S2000 Honda S2000
SQUEELING ON S2000
Old Apr 6, 2010 | 01:28 PM
tuned94eg's Avatar
Default SQUEELING ON S2000
I have an 02 S2000 with 68XXX on the clock. It has a squeeling noise that occurs at 3500 rpm ONLY. For the life of me I can't tell what it is. I have not had someone rev it while I listen because I have been extremely busy with work. I plan on doing that tonight. Just seeing if any other s2k owners have had any similar problems? Thanks for any info. I tried search but came up short handed.
Old Apr 6, 2010 | 04:54 PM
c-rex23's Avatar
Default Re: SQUEELING ON S2000
i have the same problem it just started 2 weeks ago and cant seem to figure it out either, my air filter needs to be changed which i think could be it but if someone knows that would help. Mine sounds from 3000-4000 rpm and then goes away, its a small squeal too.
Old Apr 6, 2010 | 05:26 PM
hrtagrm's Avatar
Check the drive belt. I knew someone whos S2k was doing the same thing. New belt took care of his problem.
Old Apr 7, 2010 | 01:53 PM
theineffable's Avatar
is it a quiet whistling sound? the oem intake makes a whistling sound at certain rpms. it's even more noticeable w/ a k&n drop in filter or aftermarket intake.
Old Apr 7, 2010 | 02:36 PM
c-rex23's Avatar
well the noise on my car comes when im driving only not when im parked and rev up. I do have my stock air intake box out the whole thing but just temporary so maybe your right
Old Apr 7, 2010 | 09:15 PM
kevinnuh's Avatar
i actually got a k&n drop in filter or aftermarket intake that came with the car and im hearing the same exact thing but it is true what u said, its more noticable without the oem intake, after reading your post i'd thought i'd share my whistling noise as well.
Old Jun 9, 2010 | 09:28 AM
tuned94eg's Avatar
Any more thought in this?
Old Jun 10, 2010 | 11:46 AM
mingus's Avatar
Stitches for snitches.
Old Jun 10, 2010 | 01:20 PM
dc2JDMwhore's Avatar
I see......weirdo
Old Jun 10, 2010 | 02:12 PM
camoy's Avatar
Some questions to possibly help narrow it down.
Does the noise happen at 3500 rpm in all gears or only some?
Does it go away once the car has warmed up?
Are you driving in a straight line or turning the corner?
Old Jun 11, 2010 | 05:59 AM
tuned94eg's Avatar
It happens in most every gear but not all the time.
It does it when it is cold or warm.
It does it either way.
Old Jun 11, 2010 | 07:40 AM
camoy's Avatar
Have you checked your belt this sounds a lot like that since it is occuring in all the above situations.
Old Jun 11, 2010 | 08:36 AM
BloodRedS2k's Avatar
Ya i'd wager its some sort of belt out of whack.. You know when you hear that old astro van coming out of the parking lot, real loud squeek.
Old Jun 11, 2010 | 02:03 PM
mingus's Avatar
Originally Posted by dc2JDMwhore
I see......weirdo
No, you don't...... retard
Old Jun 12, 2010 | 05:47 AM
tuned94eg's Avatar
Belt has been changed and still same thing. I removed a heat shield thinking it was that but it wasnt. Guess it's best fit to take it to honda. I don't want to but I gotta keep her healthy.
Old Jun 12, 2010 | 11:50 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
It's probably just the intake whistle. If it is...then that's normal. The intake will whistle...even the stock box whistles sometimes. It happens only at certain RPMs and throttle positions.
Old Jun 13, 2010 | 05:58 AM
envee's Avatar
The most important part of this post is throttle position. Try this, when you are driving and it starts making the noise either floor it or let off the gas. If the noise stops then it is just intake whistle, if it does not stop the take the car to get serviced.
MonKK
Honda S2000
71
Mar 19, 2013 03:16 PM
mainevent177
Honda S2000
Mar 6, 2006 10:45 AM
ExtremePowerOuters
Honda S2000
Feb 12, 2004 06:38 PM
rapidlee337
Honda S2000
11
Dec 20, 2001 10:19 AM
