Honda S2000 Honda S2000
squeaky brakes
Old Oct 25, 2005 | 08:48 PM
tyrone's Avatar
Default squeaky brakes
i recently cleaned my brakes w/ brake cleaner... like i took the wheels off and totally sprayed them like crazy to get the grease stuff off...
Well a few days later, brakes started squeaking... Any ideas????
Old Oct 25, 2005 | 08:50 PM
p nut's Avatar
Lube up those pads.
Old Oct 25, 2005 | 10:00 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: squeaky brakes (tyrone)
Shin-Etsu grease on those shims.
Old Oct 26, 2005 | 10:13 AM
* B A N N E D *
Default Re: squeaky brakes (Honda S2000)
1 set of AP1 pads, 2 sets of AP2 pads, only squeaked once. I glazed my pads at the track, had to burn that shiny surface off.
Old Oct 26, 2005 | 08:18 PM
* B A N N E D *
Ok first of all, for asking those questions, smear some grease on your forehead. jk
Now for the easy part. The shim is the thin piece of aluminum that attaches to the back of the pads. Apply the grease to the back of the shim, the side that touches the caliper piston.
Voila.
Old Oct 28, 2005 | 06:08 PM
* B A N N E D *
You definitely have to remove the wheels to change or service your brake pads.
Old Oct 28, 2005 | 10:10 PM
SuzukaBlueAP2's Avatar
Default Re: squeaky brakes (Slideways2000)
i have noticed annoying squeaking with my 04's brake pads. At first i thought they were getting worn down, but after inspecting them, they just need greased. I have just been too lazy to do it. After all, i've only put 100 miles on the car in the past 3 months.
Old Oct 28, 2005 | 10:34 PM
* B A N N E D *
Default Re: squeaky brakes (ScreaminTeg)
Wow. On my Berlina I put down 18k miles in 6 months, on the GPW 6.4k in 5 months. You're S must feel lonely.
Old Oct 29, 2005 | 07:47 AM
* B A N N E D *
There are 2 caliper mounting bolts. They are 17mm socket. You need to take one off and loosen the other one so you can swing the caliper out and access the pads.
matryx
Sep 13, 2008 12:54 PM
Poopie
Jun 25, 2004 07:03 PM
OEMaccord
13
Sep 20, 2002 11:08 AM
internet ay
Apr 28, 2002 07:32 AM
blkbeast
Jan 14, 2002 12:58 PM
