Honda S2000 Honda S2000
Squeaks and Noises
Old Jan 3, 2008 | 11:10 AM
al4t1gbundy's Avatar
Default Squeaks and Noises
Well I know that the S has squeaks and noises, but Im curious if this is normal.
The exhaust tends to ping a lot more than any other cars I own. I mean the ping noise I understand is normal at times, but it's pinging a lot. Not sure if that makes sense. Im only asking this because I smell the exhaust often when I open my trunk.
I also hear this sound like something is loose coming from the passenger rear. This was noticed after I installed Espelir's .. not sure if one has to do with another. Im guessing maybe it could be the spare tire area? I cant duplicate it without driving over bumps.
Are these normal?
Old Jan 3, 2008 | 11:35 AM
Import_Fan's Avatar
Default Re: Squeaks and Noises (A08_MThrizzle)
I don't have those noises but I have my own. Something from behind the seats squeaking. Maybe the top against something. I have '02 clutch buzz. I have alot of transmission noise actually. But other than that, not much to speak of here.
Old Jan 3, 2008 | 11:45 AM
papa5murf's Avatar
For the one from the rear passenger side. Check the spare tire area, the thing you screw to hold the spare down. You might have it set up wrong or might not be tight enough.
Other squeaks are usually from the soft top. You can get some Shin-Etsu grease and apply it on various areas of the top, sometimes it'll help a little. Also check your strikers. There's also an annoying sound from the seatbelt (one rubbing on the leather, and on the passenger side it bouncing off the side making plastic to plastic contact).
Old Jan 3, 2008 | 12:30 PM
envee's Avatar
I get some rattle from my top when i go over rough pavement or RR tracks. Its a convertible, there will always be noises.
Old Jan 3, 2008 | 12:50 PM
CrankDatVtec's Avatar
Default hmMm
i get a rattling noise from behind me to the right, at times i think its my exhaust, all hangers are in place so i start wondering if it might be something in my suspension, Im pulling it out this weekend to make sure, hopefully i can see whats wrong. i think the spring might not be sitting on the perch correctly.
Old Jan 3, 2008 | 01:46 PM
ITS_THAT_S2K's Avatar
EVERYTHING SOUNDS GOOD ON MY CAR THE ONLY THING THAT BUGS IS IN THE INTERIOR I KEEP HEAR A RATTLE ON THE PASSENGER SIDE BY THE SEAT BELT
Old Jan 3, 2008 | 03:51 PM
NFRap1's Avatar
i hate it when im on the freeway and my top "pops" from the wind simulating a backfire...it always get me scared
Old Jan 4, 2008 | 12:03 AM
f1 vtec's Avatar
Default Re: (NFRap1)
Those closing clips on my soft top rattle, but no squeaks as yet. Squeaks are more annoying then rattles i think hmm...or maybe not
Old Jan 4, 2008 | 12:56 AM
Nagata-San74's Avatar
Usual noises on Ap1
-clutch "griiiiiiiiii" around 2500-4000
-rear end "whoooooo" around 3500-4000
"scrukk srukkk" from the hardtop when road not flat
"schrinnnn schrinnnn" passenger seat on back (move it 1 step front)
"hiiiiiiiiiii" Carbon brakes (like Carbone Lorraine or DS3000 brake pads)
"Whouuuuu" Aem V2 on idle
"BrroooooAAAAAAA" Vtec kicks in
Modified by Nagata-San74 at 11:19 AM 1/4/2008
Old Jan 4, 2008 | 01:42 AM
Mr. Projekt's Avatar
* B A N N E D *
Nathan, check the passenger side strut tower. I'm willing to bet $5 someone forgot a nut in the pocket of that passenger rear suspension, if it's NOT the spare tire lock.
The pinging is somewhat normal, if you only notice it after shutting off the motor. The aluminum head/block doesnt' cool down or contract(expand) at the same rate as steel parts, therefore creating "squeaks" and "pings' when metals cool down at different rates. As mentioned, this should only happen after shutting off the car. To make it simple..
"Exhaust and exhaust manifold are STEEL, mated to an ALUMINUM block and head."
Old Jan 4, 2008 | 01:44 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: (Nagata-San74)
So is this "hiiiiii" noise I hear from my rears when I brake semi-hard normal?
I know it isn't brake dust...
I thought it could be some of the rear clips that I could just bend back. I haven't really taken the wheels off to inspect. Just wondering...
I have a hard top and I get the annoying "latch" noise. I also have this rattle inside my driver side door. Seems to be coming from the speaker area.
I'm getting used to it. Not as bad as when I had my DC2
Old Jan 4, 2008 | 08:53 AM
Default Re: Squeaks and Noises (Mr. Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Nathan, check the passenger side strut tower. I'm willing to bet $5 someone forgot a nut in the pocket of that passenger rear suspension, if it's NOT the spare tire lock.
My man Dang .. long time no see. I was guessing it was something freaking loose or missing. Let me check.
Thanks.
Old Jan 4, 2008 | 10:05 AM
romo365's Avatar
I have a weird noise coming form under the driver side floor. it sounds like a loose heat sheild. I had a Celica and the noise sounds the same. I fixed it in the Celica but cant seem to find the cause of the noise in my S2K.. any help would be nice. oh yea i weigh about 175 @ 5'10
Modified by romo365 at 1:31 PM 1/4/2008
Modified by romo365 at 1:32 PM 1/4/2008
Old Jan 4, 2008 | 12:19 PM
Default Re: Squeaks and Noises (romo365)
hMmMm on both cars you say, on the drivers seat.........are you fat?
lol..im playing man
doood
Jun 5, 2011 05:34 PM
Integra4lyfe069
Jul 30, 2008 11:20 PM
vlc92189
Sep 2, 2007 03:28 PM
hecklervtec
Apr 8, 2004 09:41 AM
h22mark
Nov 1, 2003 05:25 PM
