Honda S2000 Honda S2000
Spark plug wire cover bolt help
Old Apr 22, 2014 | 04:24 PM
slow_low_eddie's Avatar
Default Spark plug wire cover bolt help
Hey guys I need help taking this last allen bolt out. This is exactly why I don't let just anyone work on our cars. What do you guys suggest? I tried hammering a bigger size allen key but to no avail.
Old Apr 22, 2014 | 06:25 PM
lazlong's Avatar
Default Re: Spark plug wire cover bolt help
A larger allen and an impact.
EDIT: I mean a manual impact. Like this one: http://www.harborfreight.com/7-piece...set-93481.html It's a little more work because you have to hammer it but, it's not quite so hard on the parts.
Old Apr 22, 2014 | 06:32 PM
Originally Posted by lazlong
A larger allen and an impact. EDIT: I mean a manual impact. Like this one: http://www.harborfreight.com/7-piece...set-93481.html It's a little more work because you have to hammer it but, it's not quite so hard on the parts.
How exactly do I use this? Do I also use the slightly bigger allen key that I have?
Old Apr 22, 2014 | 06:33 PM
How exactly do I use this? Specific way? Also, do I use the slightly bigger allen key with this impact driver?
Old Apr 22, 2014 | 07:36 PM
lazlong's Avatar
You're gonna have to find a slightly bigger allen than the hole that fits onto/into the end of the impact. Some more expensive impacts have socket ends, that one is just a cheap example.
You hold the impact in 1 hand and whack it with a hammer. Every time you hit it with the hammer it will twist a little (you should be able to feel the twisting). If it's twisting the wrong way then twist the collar to make the impact twist the other way.
Old May 15, 2014 | 06:21 PM
CobraRed's Avatar
Tack weld a large allen on it. Sometimes i cut a slot on a bolt and use a flat head as well.
firaga21
Nov 4, 2008 05:29 AM
madlion
15
May 17, 2007 01:56 PM
vortexx
Jan 4, 2007 04:48 PM
96BlackHB
Jan 15, 2004 05:30 AM
::mebri::
May 18, 2003 06:57 PM
