Honda S2000 Honda S2000
Shock absorber question
Old Mar 31, 2010 | 04:08 PM
trepteg's Avatar
Default Shock absorber question
Hi ,
I had the change a rear shock absorber on my 2005 ap2 . I bought a used one from a guy and he told me that it was a ap2 one . I installed it , and now the car is a little higher on this side
I read that the ap1 get about 10% higher than a ap2 , maybe it's a ap1 shock ?
I want to know if the shock absorber is the same and only the spring change ? because If yes , I'll only change the spring for a ap2 one
Thanks !
Old Mar 31, 2010 | 07:00 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Shock absorber question
Well, the "strut" shouldn't change the height of the car. The spring is the piece that "holds the car up". How much is the variance? Very noticiable?
Old Mar 31, 2010 | 08:59 PM
bky's Avatar
bky
Agreed: shocks should not change your static ride height.
I suspect bushing preload from the shock change, or sway bar preload from not lifting the entire axle off the ground before reconnecting the end links.
My 2 cents.
Old Apr 3, 2010 | 09:26 AM
Black S2K's Avatar
^x2 fosho
mikeunreal2
Jul 25, 2006 05:08 AM
the.hamburglar
Suspension & Brakes
Jun 29, 2005 11:03 PM
WangChung
Jul 17, 2003 01:55 PM
jansenrw
Apr 16, 2003 06:25 PM
comptechgsr
May 31, 2002 03:06 PM
