s2k drivers.. need answer quick..
RPM is not correct... 9,000 seems better.
here is some info.
http://www.s2ki.com/article/articleview/15/1/31/
here is some info.
http://reverendsgarage.net/index.php...calculator.php
this one works too if you are looking at individual gear ratios or contemplating changing out the final gear.
it's not correct. there's an additional reduction after the tranny. the total reduction ratio after the individual gears is 4.756:1, the fuel cutoff is at 8900-9200, depending on who you believe, and while the tire diameter is listed as 24.8 as you have it, it also is spec'd at 840 revolutions per mile, which translates to only 24.0 inches, possibly because the 24.8 figure is unloaded.
litterbox
May 22, 2005 08:26 PM
il8apex
Nov 27, 2001 10:48 PM
