Honda S2000 Honda S2000
s2000 upgrade?
Old Oct 2, 2004 | 04:15 PM
JS2K's Avatar
Default s2000 upgrade?
so i wanted to upgrade my s2000 but i dont know how much of a difference would it make if i just changed the cams/ valves and valves springs. Puls how much do you guys think thats gonna cost. Plus do i have to change program on the ECU>
Old Oct 2, 2004 | 06:59 PM
cmdr430's Avatar
Default Re: s2000 upgrade? (JS2K)
first off if you are not going to have any head work done dont worry about the valves at this point... i.e. porting,polishing etc...
as far as cams and valve springs you should definately have some sort of fuel computer.... i.e vafc or standalone aem ems
what other mods do you have?
to realise the full benefits of the cams you will need a intake, header,and possibly a single outlet exhaust....
cams will make more power if you are able to free up the intake and exahust breathing capabilities and with proper fuel and ignition tuning...
good luck
Old Oct 3, 2004 | 12:05 AM
Formula 1's Avatar
Default Re: s2000 upgrade? (cmdr430)
i calculated how much i would spend on a good NA setup and it turned out around 15K with just parts and those were just the parts i know i need
Old Oct 3, 2004 | 05:38 AM
BOOSTEDS2K's Avatar
Default Re: s2000 upgrade? (SikCivic)
When I was going to do an N/A set up it was going to be arround 14K so i just went turbo and spent the same....... Car should Have about 480whp... we will find out in a few days
Old Oct 3, 2004 | 11:33 AM
JS2K's Avatar
cool thanx man. but wont the cams put more stress on the other parts of the head?
Old Oct 3, 2004 | 01:45 PM
PNB's Avatar
PNB
GatorNATION
If you want to make any real power, you're going to have to go FI.
The power to cost ratio of NA is just too much.
SuperTwinz
Feb 7, 2013 07:11 PM
phil_space
Sep 6, 2009 11:04 AM
supercivicstack
Honda S2000
11
Jul 30, 2009 04:37 AM
Outlawjb
Honda S2000
Feb 18, 2004 06:26 AM
