Honda S2000 Honda S2000
installing cams in s2000 need help
Old Feb 12, 2004 | 08:29 AM
Outlawjb's Avatar
Default installing cams in s2000 need help
i am working on a s2000. i have a cam kit with valves and all. when i prep the head do i have to lap the valves or is there a different way. i noticed that they are aluminum. or is there anything else i have to watch out for. thanks
Old Feb 12, 2004 | 09:05 PM
KF_S2000's Avatar
Default Re: installing cams in s2000 need help (Outlawjb)
I don't know too many folks that have tried this. What cams are you installing? (well, this might be a dumb question now that I think about it, because I think that Toda is the only company currently making cams for the F20C.)
Just check the instructions that came with the cams, the recommended clearances should be in there. If not, just keep it within spec. Remember, cams are cams. Sure, the ones you are installing have a slightly different characteristic than the stock ones, but they do the same thing mechanically, open valves.
I'm not sure what you meant by "lap" the valves though? Are you referring to valve overlap? And when you say aluminum, are you referring to the valves? No offense, but I'm going to have to disagree with you there. I'm pretty sure the valves are steel (maybe stainless?)
Are you going to do any mild porting of the head? What cam gears are you installing with your cams?
And last note, get a Helms manual if you don't already have one. Trust me.
Old Feb 13, 2004 | 05:08 AM
00MRSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outlawjb &raquo;</TD></TR><TR><TD CLASS="quote">i am working on a s2000. i have a cam kit with valves and all. when i prep the head do i have to lap the valves or is there a different way. i noticed that they are aluminum. or is there anything else i have to watch out for. thanks</TD></TR></TABLE>
If you have little to no experience, I would not perform this task..
Old Feb 13, 2004 | 01:07 PM
profpin's Avatar
Default Re: installing cams in s2000 need help (00MRSi)
machine shop is your friend..
Old Feb 13, 2004 | 02:37 PM
88 turbo crx's Avatar
Default Re: installing cams in s2000 need help (profpin)
Im am your friend, Stay away from that f20c valvetrain man, your going to get yourself in trouble
If you wanna send me the head i can do the work for you
mike
Old Feb 18, 2004 | 06:26 AM
CHEETAH's Avatar
you only lap valves when you're changing the valves similarly you would have to recheck valve spring height.
The installation you're trying does not require that, simply install springs and retainers and camshafts.
Greg
EFjoe91
54
Mar 10, 2011 08:17 AM
eg6REDmilano20
Dec 22, 2009 05:03 AM
matata55
Dec 23, 2004 09:54 PM
