Honda S2000 Honda S2000
s2000 spring options
Old Jun 2, 2003 | 05:31 PM
nutsack's Avatar
Default s2000 spring options
looking to get a set of springs to get rid of the wheel gap. not sure on what my options are, i've definitely noticed that s2000 parts are not as plentiful as civic/integra parts. any pics would be helpful too. i don't plan on getting anything larger than a 16'' rim.
Old Jun 2, 2003 | 07:00 PM
Razor's Avatar
Default Re: s2000 spring options (*******)
get neuspeed sport springs, they're perfect IMO. they reduce the gap but without that "ghetto drop" look. i suggest upgrading to koni yellow shocks since you'll end up changing your OEM shocks a couple months/years later.
OR
you can spend the same amont for a true coilover setup,and you can adjust the height as needed. i used to like Tein, but lots of people are having problems with leaks.
Old Jun 4, 2003 | 09:20 AM
nutsack's Avatar
Any other spring options?
Old Jun 4, 2003 | 11:39 AM
tubedriver's Avatar
Default Re: (*******)
Ground Control makes an adjustible coilover/sleeve for the OEM shock. It uses Eibach race spring (linear rate) front 340/rear 380. These have been used on the track and appear to do a good job. When you decide to upgrade, you can order the Advanced Design Ground Control coilovers (12 way adjustible, CNC machined AL bodies, Titanium and SS internals, completely user servicable) and reuse the springs for $900 more. Best bang for the buck, adjustible height, race proven and from a company with a huge racing presence.
Old Jun 4, 2003 | 01:03 PM
SRV's Avatar
SRV
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******* &raquo;</TD></TR><TR><TD CLASS="quote">Any other spring options?</TD></TR></TABLE>
Ya u can get KG/MM springs. or for coilovers u can think about buddy club, spoon or zeal.
Old Jun 5, 2003 | 12:11 AM
arcticblursx's Avatar
I'd rather stick with Teins...RA if you can afford them..however the CS do quite the trick...
Old Jun 5, 2003 | 02:47 AM
Art Vandeleigh's Avatar
Default Re: (arcticblursx)
the rear shocks have an ext. resv. is that correct?? or are they on all four corners?
Old Jun 5, 2003 | 05:31 AM
nutsack's Avatar
i've heard bad things about neuspeed springs for the s2k, that they actually worsen performance over stock springs. can the stock suspension actually be improved with springs, or a full coilover setup the only way to go?
Old Jun 5, 2003 | 05:33 AM
PornStarRacingB16T's Avatar
Many think that full coilover setups are the way to go. Some insist you can get away with just springs. Boils down to if you want to mix and match pieces (shocks, CO sleeves, springs) or go with one system all made by the same company.
-J
s2kwildride
Honda S2000
13
Mar 17, 2007 12:53 AM
BassBoy19
Honda S2000
19
Mar 11, 2004 07:12 AM
Showoff
Apr 1, 2003 08:45 PM
4glude
Oct 25, 2002 07:25 PM
ExAcc
Oct 3, 2002 05:04 AM
