S2000 homemade spoiler
Guest
Posts: n/a
Re: S2000 homemade spoiler (GSR)
It's at http://www.nsxfiles.com and from what's on the site, it does seem to work...
Re: S2000 homemade spoiler (VTEC)
uhm.
that thing looks like it crosses the boundry of actually working properly.
it would create lotsa downforce but huge drag. so i mean hes prolly gaining nothing...
i was reading how F1 racers adjust and design the wings on there cars. they use a wind tunnel and the area of minimizing drag and maximizing drag is very small.
i cant see how that piece of sheet metal would work unless its been tested in a wind tunnel and measured.
Re: S2000 homemade spoiler (shortyz)
If you read the article in nsxfiles, you'll see that it was quite effective, dropping quite a bit of the lap times. It may be crude and I'm sure it can be improved, but the basic idea worked well.
Re: S2000 homemade spoiler (RIPF23A5)
There's never enough time to get things built right - I had wanted to do more with it but ran out of time. It sure did work well. I was going to take it off as soon as I got back from the track, just been too lazy to put the red trunklid back on.
It's coming off in the next day or two to be replaced by a much bigger, but hopefully prettier, rear wing.
Anybody know where I can get a set of the JDM 6-spoke S2000 wheels? PM or email me please.
-Jason Rhoades
-Jason Rhoades
1 Post
Re: S2000 homemade spoiler (jzr)
somebody was looking at server logs
I'd try Leo at jspec (www.jdmspecperf.com) or user Unlimited on this board.
For all you poo-poo'ing on the "looks" keep in mind that is a -> spare <- trunk lid Jason rigged the spoiler up on.
Re: S2000 homemade spoiler (jerrypeterson)
Hey Jason good to see that you went ahead with the wing, so any dents in the rear truck that we all were predicting about, or no chance for a high speed run yet.
Re: S2000 homemade spoiler (StormBringer)
When I pulled off the lower two brackets a couple days ago I noticed the bolt holes had elongated a tiny tiny bit. Probably more force than should be transmitted laterally through the metal. Other than that everything is hunky-dory.
I think you're going to see lots of spoilers and wings at future SpeedVentures events.
Well jason to keep up with you they are going to need quite a bit more then a big wing, but looks like you had fun with it though.
El Chico
Re: S2000 homemade spoiler (Mrfirefox)
It looks like he was using it for AutoX?
I may be wrong but I don't think you can gather enough spped to create any useful downforce. I'd be willing to be that the positive effects you sensed were more a product of drag than downforce. You effectively created an always on "air brake."
If you really want to do something worthwhile. Fabricate an underbody panel with two or three scoops to create the Bernoulli(sic) effect.
Re: S2000 homemade spoiler (Knightsport)
A stock S2000 is known to generate approximately 88 pounds of lift in the rear at 100mph. This lift is the result of the low pressure region created over the trunklid while at speed. The spoiler reduces that lifting. For more information on the effect of spoilers of this type check out the SAE papers referenced in Katz's <U>Race Car Aerodynamics: Designing for Speed</U> or Milliken & Milliken's <U>Race Car Vehicle Dynamics</U>.
This reduction in lift does come with a drag penalty. But at the track, speed through and exiting the corners is everything. If you are able to exit a corner carrying 5mph more speed, it more than makes up for 5mph less acceleration down the straight. At a higher speed track I'd probably run the spoiler at a lower angle of attack - at the low speed Streets of Willow, I saw no need to adjust it.
The wing I'm building to use at Laguna Seca next month will be quite a bit more dramatic. I urge you guys to come out an attend a real track day. The group I run with, SpeedVentures (http://www.speedventures.net), is hosting 2 days at Sears Point and 2 days at Laguna Seca next month. They're a great group, and it's always a lot of fun.
Re: S2000 homemade spoiler (sslude)
is that guys serious? is that guy your friend or did you just see him? that is just mean to do that to a beautiful car.
Re: S2000 homemade spoiler (BitterCivic)
... ummm okay...
Is it really that neccessary? I don't think I would submit my S2k to that level of humiliation...
Moderator in Chief
Re: S2000 homemade spoiler (Variance)
Ummm okay, did you not read the whole thread? He still has his stock trunk unmolested. He just uses this for the track!
Like he said... at the track.
Thats f*cken stupid (There - someone had to say it)
[Modified by Muckman, 6:56 PM 12/30/2002]
