Honda S2000 Honda S2000
S2000 ap1 problems.
Old Jun 28, 2010 | 01:05 PM
cesshonda's Avatar
Default S2000 ap1 problems.
Hello Everyone hope to get help from you guys
I have bad sound at the gas release ,sounds like the exhaust system receiving somewhere but they do not. sounds from the center under the car. Can it be gearbox?
Other problem is when I drive slowly back. It sounds from the rear axle 03. just shortly time.and not always.what shall I do?
I have change the oils to the original bought from honda.
This is my car
Old Jun 28, 2010 | 01:06 PM
cesshonda's Avatar
Default Re: S2000 ap1 problems.
http://www.garaget.org/?car=205089&image=1935905
Old Jun 28, 2010 | 03:36 PM
JUSTINTHECOASTI's Avatar
If what you are saying is that youre getting a weird sound when you release the gas pedal, it sounds like exhaust is exiting through where the gearbox is but under the car, then you probably want to check the bolts and gaskets at the header and catalytic and also at the catalytic converter leading to the exhaust, also check your catalytic converter it could be faulty...
I dont understand your second question sorry
Old Jun 30, 2010 | 06:59 AM
cesshonda's Avatar
Thank you. I looked and search for SMELL off exhaust, there were no such things.
it sounds sometimes at low idle.
At high speeds, when I release the gas allows the same audio...can it be the Release bearing?
Old Jun 30, 2010 | 12:08 PM
S2K-APWON's Avatar
Is it a kind of a buzzing sound? AP1 are known to have "clutch buzz", nothing to worry about.
Old Jun 30, 2010 | 01:30 PM
4doorH22's Avatar
Here is the Technical Service Bulletin on the "clutch buzz" Buzzing From the Engine or Transmission While Decelerating.
I can't quite understand your second problem either. Might be this: Rear Vibration During Acceleration.
Old Jul 1, 2010 | 12:50 AM
cesshonda's Avatar
thank you very much.! Yeah thats the problem (whit the buzzing sound ! now Iam going to buy new clutch set .I have now sinter 6 pucks clutch ..were can I buy Clutchmaster? I hate ebay !
The other problem from the rear axel..I have lower the car.And I dont have that spacers between the diff and the axels ..shell I buy them?
Old Jul 1, 2010 | 01:08 PM
bigmacnfries's Avatar
you'll only need axel spacers if you experience vibration - that said, it's not a bad idea to do them anyway if you have the time/money
Old Jul 7, 2010 | 01:38 PM
cesshonda's Avatar
thx man:D The Spacers is on the way from US and A to sweden now:D
sorcpwn
May 6, 2009 10:06 AM
eddiec
Honda S2000
10
Apr 4, 2009 01:06 PM
JTStreet
Honda S2000
42
Mar 25, 2009 05:02 AM
JMcDB18C
Honda S2000
Oct 29, 2005 01:14 PM
Dave421
Honda S2000
10
Jan 21, 2003 09:41 AM
