Honda S2000 Honda S2000
s2000
Old Apr 24, 2008 | 12:03 PM
benlen11's Avatar
Default s2000 brakes
Does anyone have detailed dimensions of the calipers and mounting holes trying to compare to other makes .ie (brembo . subaru . mitsubishi etc) trying to do a cheap brake upgrade.
Old Apr 24, 2008 | 12:15 PM
Black S2K's Avatar
Y the stock brakes are awesome esp if your runnin a decent set of pads. And I dont think any of the calipers you mentioned will wok. The closest caliper upgrade I have seen that used oem brembos was brembos off of the tl-s but iy requires some work. You gotta shave down the caliper and hub 5mm for the caliper to actually fit on the hub and then you gotta run custom rotors stockers dont work. But after you have done all this you spent the same ampount of money o even more then what a bbk costs. So your kinda s.o.l.
Old Apr 24, 2008 | 12:37 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: s2000 brakes (benlen11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benlen11 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have detailed dimensions of the calipers and mounting holes trying to compare to other makes .ie (brembo . subaru . mitsubishi etc) trying to do a cheap brake upgrade.</TD></TR></TABLE>
great first post, you're off to an awesome start
my favorite s2000 brake upgrade is mounting 2 dc rear calipers to each wheel in the front of my s2000
the only downside is you need a total of 4 rear calipers to do this...but you can mix and match between the dc and da chassis
cheap dual piston caliper mod FTW
Old Apr 24, 2008 | 02:15 PM
benlen11's Avatar
Default Re: (Black S2K)
Thanks for the replie . I had 300zx calipers on my subaru before i got the s2000. Going to try them on my honda anyway there light strong and cheap and were able to stop me from 175mph (on more than one ocassion)no problem . Will post pics and measurment when i get around to doing it.
Old Apr 24, 2008 | 02:48 PM
benlen11's Avatar
Default Re: s2000 brakes (GRAF-FITI)
Thank for the info . Had 300zx 4pots on my subaru going to do the same with the honda . There cheap, light and strong will post pics and measurments when done
Old Apr 24, 2008 | 03:01 PM
LAS2K's Avatar
You moron oem brakes are more than capable of whatever your needs are.
gtfo. Unless you're Speed Racer doing 300mph or what the **** ever you're fine.
Old Apr 24, 2008 | 04:20 PM
NFRap1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
lols that sarcasm was laid on pretty thick
Old Apr 24, 2008 | 05:21 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: s2000 brakes (NFRap1)
hahaha me? NEVER!
he even thanked me for my help..to which i designed this wonderful diagram below
OP, here's what the 2 rear caliper setup on the s2000 front wheel looks like:
Old Apr 25, 2008 | 12:08 AM
Basskika's Avatar
Banned
Looks interesting .. I might go and try that - may help stopping me from 180
Old Apr 25, 2008 | 12:14 AM
dagle's Avatar
Default Re: (Basskika)
yeah guys, brake pads are NOT cheap and they do NOT help.
Old Apr 25, 2008 | 03:57 AM
HondaKyle's Avatar
Default Re: (dagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle &raquo;</TD></TR><TR><TD CLASS="quote">yeah guys, brake pads are NOT cheap and they do NOT help.</TD></TR></TABLE> what 300 dollars for a good set? thats not bad at all this isn't some civic. I noticed a differences with my new pads over the OEM.
Old Apr 25, 2008 | 04:39 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Basskika &raquo;</TD></TR><TR><TD CLASS="quote">Looks interesting .. I might go and try that - may help stopping me from 180 </TD></TR></TABLE>
your car doesnt even run... you dont need brake pads just some bricks to stop it from rolling... OHHHHHHHHH BURRRRRRRNNNNNNN!!!!!! hahaha
Old Apr 25, 2008 | 09:18 AM
nicokpe's Avatar
yeah, looks interesting haha
Old Apr 25, 2008 | 09:53 AM
joey1320's Avatar
you are a moron sir...
why would you need to swap out the oem brakes for anything mitsu/subaru/nissan has to offer???
just a waste of time and energy. just keep the stock ones and buy better(if) pads and go from there. if you want more then step up and get the 4/6 piston caliper kit.
Kamuics
Suspension & Brakes
14
Apr 8, 2012 02:29 PM
s2kb0i
Honda S2000
24
Jul 1, 2006 10:47 AM
nambiker
Honda S2000
19
Apr 12, 2006 10:51 AM
Luder94
Jan 19, 2006 08:54 PM
