Honda S2000 Honda S2000
Remote Start on S2k's
Old Sep 21, 2003 | 02:21 PM
MooreBoost's Avatar
Default Remote Start on S2k's
Has anyone ever done it? I was thinkin maybe the push button starting may interfear with it? Im looking at this alarm, http://www.gopme.com/lynx2000.html , it's designed for manual cars. Any recomendations/comments, lemme know.
gmoore
Old Sep 21, 2003 | 02:37 PM
OC 335i's Avatar
Default Re: Remote Start on S2k's (tegunderpressure)
My friend has it.
I wouldn't personally do it since I'd be scared of the car taking off on me.
As for the dummies who say it can't happen, it happened to me before.
Old Sep 21, 2003 | 02:39 PM
MooreBoost's Avatar
Default Re: Remote Start on S2k's (JMS JT)
But check out that alarm. Apparently it has a feature that enables you to remove the key, and exit the car, the alarm will keep the engine running, when you close the door, it turns off the engine. So it knows its in neutral, therefor it will remote start the next time.
gmoore
Old Sep 21, 2003 | 02:55 PM
OC 335i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">But check out that alarm. Apparently it has a feature that enables you to remove the key, and exit the car, the alarm will keep the engine running, when you close the door, it turns off the engine. So it knows its in neutral, therefor it will remote start the next time.
gmoore</TD></TR></TABLE>
-shrugs- That doesn't stop your friends going into your car and moving it into gear while playing with the shifter. It doesn't stop mechanics/body shops/detailers/etc. from accidently leaving it in gear and accidently pressing the wrong two buttons. It doesn't stop you from forgetting (although I never forgot). It didn't stop my friend from leaving it in gear when he drove for me because I was too intoxicated to drive away either.
If you could design it so it would not remote start UNLESS the car was in neutral I personally wouldn't go for it. It's just not worth the risk or hassle IMO.
Old Sep 21, 2003 | 03:04 PM
Razor's Avatar
if theres a system out there that will only allow you to remote start when the car is in neutral, then id get it. otherwise, there are too many chances for something to go wrong...
Old Sep 21, 2003 | 03:41 PM
Spankee2K's Avatar
Default Re: Remote Start on S2k's (Razor)
The remote start for manual cars does really work. You get out the car and the engine stays running. When you close the door the alarm then cuts off the engine. This will allow you to remote start it and know its in neutral. If someone opens the door before the remote start is used the alarm knows and will not allow the remote starter to engage unless you start the engine again and repeat the whole process. My buddy had it in his Prelude.
Old Sep 21, 2003 | 03:47 PM
MooreBoost's Avatar
What alarm does he have? Do you think the Clifford RSX has it?
gmoore
Old Sep 21, 2003 | 03:52 PM
Spankee2K's Avatar
I forgot the brand but I think thats the way all manual remote car starters are designed to work.
Old Sep 23, 2003 | 06:43 PM
Denny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">if theres a system out there that will only allow you to remote start when the car is in neutral, then id get it. otherwise, there are too many chances for something to go wrong...</TD></TR></TABLE>
there are systems that have this function. my friend has a clifford alarm and it wont autostart unless its neutral (ive tried)
Old Sep 24, 2003 | 07:06 AM
OC 335i's Avatar
Default Re: Remote Start on S2k's (Denny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Denny &raquo;</TD></TR><TR><TD CLASS="quote">
there are systems that have this function. my friend has a clifford alarm and it wont autostart unless its neutral (ive tried)</TD></TR></TABLE>
Could you get the Clifford Model #? I've never heard of this feature before.
Old Sep 24, 2003 | 09:03 PM
xhopefully5x's Avatar
i actually just got it on my car... but only bc i know i never put it in first! (houston is uber flat) WOW how much is that? im very attracted to bright shiny and cute gadgets
D-REW
Audio / Security / Video
Jul 14, 2009 04:22 PM
neozero999
Jun 5, 2008 07:17 PM
grandmasterflash
Jan 6, 2006 09:16 PM
aquarius
Jul 15, 2004 07:53 AM
