Honda S2000 Honda S2000
Reduce INTERIOR Ride Height?
Old Jul 9, 2008 | 08:46 AM
Required User Name's Avatar
Default Reduce INTERIOR Ride Height?
I am 6'3" and love these cars. However, when I sit in one the tack is perfectly blocked by the steering wheel. Not to mention, I have a hard time seeing out the windshield. Small problems really.
Is there anyway to reduce interior ride height?
Has anyone bolted the seats directly to the floor?
Used a thinner race seat?
Suggestions!?
Old Jul 9, 2008 | 08:48 AM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: Reduce INTERIOR Ride Height? (Required User Name)
lower seat rails will help you. buddyclub, backyard special, etc seat rails will help resolve the problem
Old Jul 9, 2008 | 01:58 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Reduce INTERIOR Ride Height? (Chris.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris. &raquo;</TD></TR><TR><TD CLASS="quote">lower seat rails will help you. buddyclub, backyard special, etc seat rails will help resolve the problem</TD></TR></TABLE>
yes
or cut off your legs and get shorter prostetic ones custom jdm fabbed up in carbon fiber
Old Jul 9, 2008 | 02:50 PM
joey1320's Avatar
Default Re: Reduce INTERIOR Ride Height? (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
or cut off your legs and get shorter prostetic ones custom jdm fabbed up in carbon fiber</TD></TR></TABLE>
this is more jdm...
Old Jul 9, 2008 | 03:51 PM
Tyson's Avatar
ive heard several ppl who have bought the back yard special BYS lowering rails were very pleased with the results.
Old Jul 9, 2008 | 10:11 PM
gospeedgo1's Avatar
Default Re: Reduce INTERIOR Ride Height? (Tyson)
how many inches do the rails on the lowest setting drop you?
Old Jul 10, 2008 | 01:50 AM
J. Funk's Avatar
Default FV-QR
Get your gangsta lean on. It'll fix the problem.
Old Jul 10, 2008 | 06:21 AM
F22PwrdS2k's Avatar
I am having the same problem, although I have figured out how to sit correctly so the steering wheel does not block the tach. I would like to know if aftermarket seat rails will bolt to the stock seat?
Old Jul 10, 2008 | 10:24 AM
F22PwrdS2k's Avatar
Default Re: Reduce INTERIOR Ride Height? (F22PwrdS2k)
NOBODY HAS AN ANSWER!!!?!????!!!! Somehow, I find this hard to belive!!!
Old Jul 10, 2008 | 10:39 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F22PwrdS2k &raquo;</TD></TR><TR><TD CLASS="quote">I would like to know if aftermarket seat rails will bolt to the stock seat? </TD></TR></TABLE>
You should be able to make any bottom mount seat rail/slider bolt to your factory seats (w/o the factory sliders). This will usually require only drilling, worst case you would need to fab up some flat adapter plates. Sorry I don't know for sure if any rail setup would be direct bolt on. I do know that WEDGE engineering can make you whatever you need for a reasonable cost.
Old Jul 10, 2008 | 12:44 PM
dartonh22's Avatar
it says on their site for stock seats, so yes they will, i didnt know they had lower seat rails until this post and i am thinking of buying them but dont know if its worth $300.
Old Jul 10, 2008 | 01:11 PM
jpaul_martinez's Avatar
Default Re: Reduce INTERIOR Ride Height? (dartonh22)
Recaro SPG with Taitec rails will seat you very close to the floor
Old Jul 11, 2008 | 12:59 PM
dartonh22's Avatar
Default Re: Reduce INTERIOR Ride Height? (jpaul_martinez)
s2ki has a thread on lowering your stock seat it involves removing the seat pan, drilling and a little hammering lowers the seat about 1.5 inches. i just did it and im not sure if i can tell the difference.
Old Jul 11, 2008 | 03:27 PM
Chris.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F22PwrdS2k &raquo;</TD></TR><TR><TD CLASS="quote">NOBODY HAS AN ANSWER!!!?!????!!!! Somehow, I find this hard to belive!!!</TD></TR></TABLE>
i already said, lower seat rails. wedge are direct bolt on. buddyclub, taitec, etc, needs some modification
Old Jul 11, 2008 | 07:15 PM
cl9ap1's Avatar
Backyard Special makes rails to lower the stock seat. All the other low mount rails are for racing buckets only.
Old Jul 14, 2008 | 06:30 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dartonh22 &raquo;</TD></TR><TR><TD CLASS="quote">s2ki has a thread on lowering your stock seat it involves removing the seat pan, drilling and a little hammering lowers the seat about 1.5 inches. i just did it and im not sure if i can tell the difference.</TD></TR></TABLE>
wheres that thread at... post link
Old Jul 14, 2008 | 06:36 AM
i my honda
Global Mod
Default Re: Reduce INTERIOR Ride Height? (S2KILLA)
http://www.s2ki.com/forums/ind...50658
Old Jul 14, 2008 | 06:41 AM
S2KILLA's Avatar
Default Re: Reduce INTERIOR Ride Height? (White Smoke)
thank you sir
Old Jul 14, 2008 | 06:46 AM
i my honda
Global Mod
Old Jul 14, 2008 | 07:17 AM
chimmike's Avatar
Default Re: FV-QR (J. Funk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Funk &raquo;</TD></TR><TR><TD CLASS="quote">Get your gangsta lean on. It'll fix the problem.</TD></TR></TABLE>
have you ever sat in an s2000?
I'm 5'11" and I cannot "lean" in any direction in the car.
and reclining the seats? Ha. Why even include the feature? lol.
Old Jul 14, 2008 | 08:18 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F22PwrdS2k &raquo;</TD></TR><TR><TD CLASS="quote">I am having the same problem, although I have figured out how to sit correctly so the steering wheel does not block the tach. </TD></TR></TABLE>
The wheel doesnt move how does it block the tach?
Old Jul 14, 2008 | 07:27 PM
JdMhEaD's Avatar
Default Re: Reduce INTERIOR Ride Height? (m R g S r)
I just put a Border bucket seat and buddy club super low down rails in. On the highest setting they set higher than my stock seat. On the 2nd lowest setting, they fit me perfectly. Im 6'1 170lbs. My legs arent hitting the center console anymore, i have room on either side of the seat now, and i at the perfect height!!
I am very pleased with the results. To bad larger 190lb + people cant fit into this same setup, unless you got some F1spec seats..
.:Made in OC:.
Feb 6, 2007 07:59 AM
Rtistik.
Mar 8, 2005 06:25 AM
Nader_D
Mar 27, 2004 05:32 PM
Andrew 825SM
11
Mar 17, 2004 10:46 AM
Audipwr1
18
Apr 14, 2003 09:37 AM
