Honda S2000 Honda S2000
rear window crack
Old Jan 15, 2006 | 10:19 PM
wrlcup02's Avatar
Default rear window crack
the other day i was folding the soft top down and i heard this crack and i figured it was nothing. Well later that night i was driving to CVS and noticed that the rear plastic window was cracked. i tapped it up for the mean time.. IT LOOKS WHACK... i need help. what should i do?? can i replace it with the glass windows? or can i get it fixed somehow???
Old Jan 15, 2006 | 10:40 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: rear window crack (wrlcup02)
How about making one thread and asking all your questions? Don't pollute the S2k forum with a bunch of threads.
To answer your question, a new softtop can be had, with glass, for around $800-900 new.
To answer your other question, you can adjust the catcher and latch to make your top fit more tightly.
Old Jan 15, 2006 | 11:17 PM
wrlcup02's Avatar
Default Re: rear window crack (Slideways2000)
is there any way i can just replace the rear window instead of replacing the whole softtop??
Old Jan 15, 2006 | 11:24 PM
* B A N N E D *
First you say glass, then you say plastic. Make up your mind.
Plastic: $174
http://www.hondaautomotivepart...CLOTH
Whole new top w/ glass: $921
http://www.hondaautomotivepart...03%29
Old Jan 16, 2006 | 05:17 AM
TL1000R's Avatar
I think what he's trying to ask, which I want to know also, is can you replace the plastic window with a glass one without replacing the entire top?
Old Jan 16, 2006 | 06:14 AM
Nishant's Avatar
Default Re: rear window crack (TL1000R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TL1000R &raquo;</TD></TR><TR><TD CLASS="quote">I think what he's trying to ask, which I want to know also, is can you replace the plastic window with a glass one without replacing the entire top?
no, you cannot. they are different, the whole top must be replaced
Old Jan 16, 2006 | 06:19 AM
papa5murf's Avatar
Default Re: rear window crack (Nishant)
since you live in NoVA.... call up nguyen at criswell honda...240-364-7183 ... tell him dylan sent you....
you can get just the plastic.. or you can swap out to a glass top... but swaping out to a glass top you need to also replace the skeleton....
PS... do not put the plastic rear window top down when it's under 45degrees.... it'll crack..
Old Jan 16, 2006 | 06:25 AM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrlcup02 &raquo;</TD></TR><TR><TD CLASS="quote">is there any way i can just replace the rear window instead of replacing the whole softtop??</TD></TR></TABLE>
yes, Billman250 on s2ki posted a thread about that...Its a PITA though...
personally, upgrade to an 02 softtop
Old Jan 16, 2006 | 01:55 PM
* B A N N E D *
I gave him both options, to replace just the plastic or the whole top and get glass with it. There isn't an option #3.
Old Jan 17, 2006 | 05:06 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">
I gave him both options, to replace just the plastic or the whole top and get glass with it. There isn't an option #3.</TD></TR></TABLE>
yes there is...
option #3 = Hardtop
Old Jan 17, 2006 | 09:43 AM
Mocky57's Avatar
Default Re: rear window crack (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">
yes there is...
option #3 = Hardtop</TD></TR></TABLE>
if i daily drove the S, i'd look at option #3... $2500 for one on the s2ki for sale section...
i had the plastic window before..it sucked.. (although it did have more visibility (when it was actually clean))
Old Jan 17, 2006 | 02:29 PM
twelv's Avatar
http://www.s2000.org/mods/top/...2.pdf
You can do a conversion with out repacing the soft top frame. I did my conversion already.
Old Jan 20, 2006 | 05:55 AM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
Default Re: (twelv)
nice conv. right up
Old Jan 20, 2006 | 07:54 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">First you say glass, then you say plastic. Make up your mind.
Plastic: $174
/thread
ExVtec
Honda S2000
Jun 8, 2009 11:23 AM
Status Sean
Honda S2000
Oct 20, 2007 09:25 PM
Scotty B
Honda S2000
37
Nov 28, 2005 10:57 AM
