Honda S2000 Honda S2000
Quick suspension question.........................?
Old Aug 29, 2005 | 12:25 PM
JusT a Cx's Avatar
Default Quick suspension question.........................?
On my previous 00 s2k i had installed the tein s-tech springs, but they blew out my struts !!! iam just wondering what springs you guys are using who have springs and not full ssuspension combos.. and did u need to replace struts ?? i heard nothing but good stuff on the titanium rs-r's ?? input is appreciated
Old Aug 29, 2005 | 12:31 PM
LBBP R's Avatar
Default Re: Quick suspension question.........................? (JusT a Cx)
i'm using ground-control. I personally think it's the best. u can order customized spring rate.
Old Aug 29, 2005 | 12:32 PM
JusT a Cx's Avatar
Default Re: Quick suspension question.........................? (LBBP R)
springs or coilovers for the ground controls?? and do you have ur stock struts still ??
Old Aug 29, 2005 | 01:44 PM
papa5murf's Avatar
the stock shocks are created for stock springs.. so when you swap out the springs it puts more stress on your stock shocks therefor they go out/blow out quicker then usual......
if you swap out springs or get a sleeve coilover (ground control), you should look into buying aftermarket shocks/struts..... most people have been using koni yellows with their springs.....
Mr. Bagel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JusT a Cx &raquo;</TD></TR><TR><TD CLASS="quote">springs or coilovers for the ground controls?? and do you have ur stock struts still ??</TD></TR></TABLE>
I hate to bring this up again, but we don't have struts on the S2000, just shocks. Strut suspension is a different configuration.
That said, ground control makes kits, whereby the components are matched up so they work together. GC creates the adjustable perches and pairs them up with Eibach springs and typically Koni shocks that are matched with the springs. They do work and you can get custom rates and valving if needed. But if your car will never see a track, there's no need to.
But once you get a GC kit, or even a simple coilover kit, make sure you take it in for a corner balance and alignment, or it will be far worse than stock.
Masho
Apr 16, 2012 10:40 AM
Tong.Y
Suspension & Brakes
Nov 8, 2009 12:40 PM
hondalove323
Honda Civic (2001 - 2005)
Jun 18, 2008 12:16 AM
kgrules12
12
Feb 19, 2006 04:44 PM
Sacker90
Apr 14, 2004 11:03 AM
