Honda S2000 Honda S2000
Quick question about compression.
Old Oct 6, 2006 | 07:11 PM
Dave_B's Avatar
Default Quick question about compression.
I'm going to look look at an S tomorrow and I plan on doing a compression test, look at the plugs, oil and all that nonsense. Just wondering, on a stock motor what the compression test should read for this engine. It's an 00, so the F20. TIA
Dave.
Old Oct 7, 2006 | 07:46 AM
iam7head's Avatar
Default Re: Quick question about compression. (Dave_B)
200ish?
make sure you do at least 7 cranks(or more but same number of time for all four cylinder)
Old Oct 7, 2006 | 08:24 AM
LAS2K's Avatar
Default Re: Quick question about compression. (iam7head)
more like 215
Old Oct 8, 2006 | 10:04 AM
Chubz's Avatar
Default Re: Quick question about compression. (LAS2K)
ANYTHING OVER 215
Old Oct 9, 2006 | 10:15 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">200ish?
make sure you do at least 7 cranks(or more but same number of time for all four cylinder)</TD></TR></TABLE>
consistancy is what you're looking for, make sure the numbers between all cylinders are equal, all plugs removed and throttle open (gas pedal down) on each cylinder test on a warm engine
Old Oct 10, 2006 | 09:59 AM
Dave_B's Avatar
Thanks guys. I'll have a new ride thread in a bit. For now, here she is.
Old Oct 10, 2006 | 10:03 AM
Chubz's Avatar
Default Re: Quick question about compression. (evil vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil vapor &raquo;</TD></TR><TR><TD CLASS="quote">
consistancy is what you're looking for, make sure the numbers between all cylinders are equal, all plugs removed and throttle open (gas pedal down) on each cylinder test on a warm engine</TD></TR></TABLE>
and also unplug the fuel injectors or the asociated fuel or some of your compression will be lost away
Old Oct 10, 2006 | 10:05 AM
cmdr430's Avatar
also, aside from the compression check....
check to see if all the TSB's have been done......as the car is out of its warranty period.... unless it is certified to 100k
http://www.s2ki.com/Home/index...id=28
http://www.s2ki.com/forums/ind...imple
Old Oct 10, 2006 | 02:00 PM
SilverDc2's Avatar
Default Re: Quick question about compression. (cmdr430)
I can't think of all the TSB off the top of my head, go to s2ki and check there was a few important ones,
Old Oct 10, 2006 | 03:12 PM
p nut's Avatar
Finally moving up, eh? (ITR --&gt; S2k)
There were recalls for the spark plugs, tail lights, and seat belt retractors.
Check for a loud whine, which might mean a failing diff. Also, put the top up, check to make sure the rear plastic window is not cracked or scuffed too bad. And take it on the highway with the top up to make sure it's sealing properly between the windshield and the top. Mine had some wind noise at above 80 mph. Oh, you'll most likely have clutch buzz.
Good luck.
Old Oct 10, 2006 | 04:40 PM
Dave_B's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">Finally moving up, eh? (ITR --&gt; S2k)
Good luck.</TD></TR></TABLE>
Tail lights? For what reason?
No loud whines so I guess I'm good there, the rear plastic on the top is hard as hell to see through but a hard top isn't to far in the future. As for the sealing of the top, well I have wind noise at very low speeds so I was already looking into how to resolve that issue. Is it the top seal, or the seal around the top of the windshield? TIA
Oh, and as for moving up or anything... I still have my R, just needed a new DD.
Dave.
Old Oct 10, 2006 | 05:19 PM
p nut's Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Tail lights? For what reason?
Dave.</TD></TR></TABLE>
Tail lights - IIRC, something like it didn't seal too well, so you'd get condensation inside of the lenses.
Looks like you have a severe case of wind noise. I'm thinking you'd need to replace the seal around the windshield and perhaps adjust the latches on the top.
And I was just kidding about the upgrade. Although, personally, I enjoyed my S a little bit more than my R, but I think largely due to not worrying about it so much.
Old Oct 10, 2006 | 06:21 PM
Dave_B's Avatar
Default Re: (P Nut)
And I was just kidding about the upgrade. Although, personally, I enjoyed my S a little bit more than my R, but I think largely due to not worrying about it so much.</TD></TR></TABLE>
I think so. I was looking at the latches, but couldn't figure out a way to adjust the thing. Any write ups or anything on the subject either here or s2ki forum?
LOL. Yeah, it was an upgrade... from an auto EG for the daily grind while the ITR is only a track car. But stock for stock, they are not comparable. 2 totally different cars really.
Old Oct 10, 2006 | 06:39 PM
cmdr430's Avatar
Default Re: (P Nut)
the red reflector would fade to pink......
Old Oct 10, 2006 | 06:44 PM
cmdr430's Avatar
http://www.s2ki.com/forums/ind...tment
congrats on the purchase btw......
in a perfect world i would have my type R again and s2k at the same time
Old Oct 10, 2006 | 07:54 PM
Dave_B's Avatar
Default Re: (cmdr430)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">
the red reflector would fade to pink......</TD></TR></TABLE>
Is this something that the dealer will cover? My LR tail light has the "pink" reflector. I was just going to find one and replace it, but if they'll cover it I'm gonna pay them a visit.
Old Oct 10, 2006 | 08:19 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">Is this something that the dealer will cover? My LR tail light has the "pink" reflector. I was just going to find one and replace it, but if they'll cover it I'm gonna pay them a visit.</TD></TR></TABLE>
If yours falls within the TSB, they should replace it. The vin list is on the front page of s2ki under TSB.
gmon
May 7, 2013 11:14 PM
SikITR01-248
Apr 24, 2005 03:46 PM
valentinecr
May 29, 2004 11:49 AM
hatch4raceb16
Nov 29, 2003 01:50 PM
Doogie Howser
Sep 15, 2002 05:26 PM
