Honda S2000 Honda S2000
Question about wheel offset
Old Sep 20, 2007 | 07:44 AM
showtymers619's Avatar
* B A N N E D *
Default Question about wheel offset
i got a ap1, and i want to put some wheels on it..
i found some 17x8 38+ fronts
17x9 33+ rears
what size tires should i go with and will these rub? im not going pass the 1 1/2 drop in the front and 2 in the rear
will the offset make these wheels stick out?
Old Sep 20, 2007 | 08:17 AM
dc-lefty's Avatar
Default Re: Question about wheel offset (showtymers619)
they will definitely stick out. max your negative camber, and roll both front and rear. the rear will need a major pull/tuck though. stick with oem size tires.
Old Sep 20, 2007 | 08:35 AM
* B A N N E D *
Default Re: Question about wheel offset (dc-lefty)
whats the max offset with having to roll and pull the fenders out?
Old Sep 20, 2007 | 11:01 AM
Project22a's Avatar
Something like 8+48 and 9+55
Old Sep 20, 2007 | 01:58 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by showtymers619 &raquo;</TD></TR><TR><TD CLASS="quote">i found some 17x8 38+ fronts
17x9 33+ rears
will the offset make these wheels stick out?</TD></TR></TABLE>
you will need to run 215 / 2 degrees camber 235 rear with 3 degrees camber...
and roll your fenders
Old Sep 21, 2007 | 04:07 PM
iloveADOBO's Avatar
Default Re: Question about wheel offset (S@nt0s)
dont worry too much about femder rolls ( SPUNKY SANDOVAL ) ISAAC ( HE'S AN SD LOCAL ) DOES A DOPE JOB @ IT. As far as the fender pull - SPUNKY can do thatg too ( seen it in person - you can barely tell - hit him up or pm me for his # if you dont have it )
santos - know it all
Old Sep 21, 2007 | 05:30 PM
* B A N N E D *
Default Re: Question about wheel offset (iloveADOBO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iloveADOBO &raquo;</TD></TR><TR><TD CLASS="quote">dont worry too much about femder rolls ( SPUNKY SANDOVAL ) ISAAC ( HE'S AN SD LOCAL ) DOES A DOPE JOB @ IT. As far as the fender pull - SPUNKY can do thatg too ( seen it in person - you can barely tell - hit him up or pm me for his # if you dont have it )
santos - know it all </TD></TR></TABLE>
i might want to get it rolled b4hand anyways .. how much he charge to do it?
Old Sep 21, 2007 | 08:29 PM
iloveADOBO's Avatar
im not sure - hit him up
he has a HT account
SPUNKY SANDOVAL ( isaac )
DUSTY4DOOR
Honda S2000
Apr 7, 2012 11:07 AM
pcteck
Jun 16, 2009 09:46 PM
Casey
Acura TSX
16
Aug 14, 2008 04:06 PM
GO-FIGHT-KILL
Jul 14, 2008 01:31 PM
RalliartRsX
Dec 12, 2005 12:34 PM
