Honda S2000 Honda S2000
Qs bout S2k
Old Oct 6, 2004 | 04:00 AM
KurwaS2000's Avatar
Default Qs bout S2k
I just need some things confirmed, oil chantes...5.1 quarts is what the book says, this correct??? are the 00-03 and 04-05 air boxes the same?? want to buy the comptech airfilter and it says fits stock air box, but I dont know if it fits 04... also is it ok to switch to higher quality diff. lubricant after 3000 miles??
Old Oct 6, 2004 | 12:58 PM
SuzukaBlueAP2's Avatar
Default Re: Qs bout S2k (KurwaS2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KurwaS2000 &raquo;</TD></TR><TR><TD CLASS="quote">I just need some things confirmed, oil chantes...5.1 quarts is what the book says, this correct??? are the 00-03 and 04-05 air boxes the same?? want to buy the comptech airfilter and it says fits stock air box, but I dont know if it fits 04... also is it ok to switch to higher quality diff. lubricant after 3000 miles?? </TD></TR></TABLE>
Yes, 5.1 quarts of oil.
The air filter should fit any 00-05 air box.
What do you mean by "higher quality" diff. fluid? There really isn't any needs to switch diff. fluid. Some aftermarket brands will cause premature wear and be required to change more often than OEM fluid. IMO, just stick w. OEM Honda diff. fluid.
Old Oct 6, 2004 | 01:11 PM
JS2K's Avatar
the oil is exactly whats is said in the manual or where you read it. as far as the air box i think i saw and ARC box for the s2000. It look sick. the best oil i think is the one form the honda dealer at least for the tranny.
Old Oct 6, 2004 | 01:56 PM
tmkpres's Avatar
Default Re: Qs bout S2k (JS2K)
I just changed my diff and tranny fluid all to redline I like it a lot. I dont have that notchy feeling in the morning when the tranny is cold, and at high rpm shifts the gears just glide in !!!!!!!!!!!
By the way tranny oil is redline MTL
diff. oil is redline 75w-90
ef8-dc2619
Apr 22, 2007 09:49 AM
DB8-teggy
Oct 19, 2006 05:50 PM
dc2lun
Jan 16, 2004 09:51 AM
AMG
Nov 8, 2002 04:54 AM
LANEVOIX
12
Oct 23, 2002 02:58 PM
