Honda S2000 Honda S2000
Problems Of My 2002 S2000
Old Sep 1, 2004 | 02:23 AM
NorthCyprus's Avatar
Default Problems Of My 2002 S2000
Hello, my 2002 - S2000 have a few problems, like
my car has an exhaust system connected form the manifold, and my guy in the serviced told me that it's too big and the car will loose performance on the lower rpm and gain performance in the higher rpm! is this true?
Another problem is the Octane Level of the petrol used in my country, the unleaded petrol here is around 85 octanes , what kind of problem would that make in the car? because i had a problem; i was pressing the gas and sometimes the car doesn't response, sometimes it does, sometimes it doesnt response at all! i loose performance and i get no response from the gas pedal. What might have caused this?
I have another question which is about the oil and the exhaust.
My exhaust outputs some black dirty staff , might it be oil? what is it if it's not? my mechanic said it's not oil than what is it? please help me on this.
And finally how often s2000's normally loose engine oil? in kilometers or miles please tell me when normally the oil level goes low!? when do s2000 owners normally get it changed?
Thanks very much for your help!
Old Sep 1, 2004 | 05:31 AM
jolt-tsp's Avatar
Default Re: Problems Of My 2002 S2000 (NorthCyprus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthCyprus &raquo;</TD></TR><TR><TD CLASS="quote">Hello, my 2002 - S2000 have a few problems, like
my car has an exhaust system connected form the manifold, and my guy in the serviced told me that it's too big and the car will loose performance on the lower rpm and gain performance in the higher rpm! is this true?</TD></TR></TABLE>
Thats pretty much accurate. The s2k motor revs high and therefore the components are designed to match that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthCyprus &raquo;</TD></TR><TR><TD CLASS="quote">Another problem is the Octane Level of the petrol used in my country, the unleaded petrol here is around 85 octanes , what kind of problem would that make in the car? because i had a problem; i was pressing the gas and sometimes the car doesn't response, sometimes it does, sometimes it doesnt response at all! i loose performance and i get no response from the gas pedal. What might have caused this?
My exhaust outputs some black dirty staff , might it be oil? what is it if it's not? my mechanic said it's not oil than what is it? please help me on this. </TD></TR></TABLE>
edit: I was totally wrong about this so I edited it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorthCyprus &raquo;</TD></TR><TR><TD CLASS="quote">And finally how often s2000's normally loose engine oil? in kilometers or miles please tell me when normally the oil level goes low!? when do s2000 owners normally get it changed? </TD></TR></TABLE>
Mine never lost any, although I've heard there was a TSB or somethign for the motors losing oil. Wait for someone else to chime in about that (as well as the other things I pretty much guessed about)
Edit: Found this thread about the oil consumption https://honda-tech.com/zerothread?id=975430
Modified by jolt-tsp at 11:01 PM 9/1/2004
Old Sep 4, 2004 | 09:02 PM
evil vapor's Avatar
Default Re: Problems Of My 2002 S2000 (jolt-tsp)
you need to run higher octane to avoid detonation, at least 91 octane.
TotalBalance
Honda S2000
Nov 20, 2012 03:23 PM
NorthCyprus
Honda S2000
26
Oct 26, 2004 05:21 PM
harry2u
Honda S2000
11
Feb 17, 2004 07:18 AM
DevilS2000F
Honda S2000
14
Jul 16, 2002 06:56 PM
