plastic cleaner
Take off the eleven gold 10mm nuts that hold the rear edge of the rear end of the softtop down, remove the metal plates, and peel your softtop forward over the frame/roll hoops. This is done with the top up, of course.
Munkyw3rkz.webs.com
put a towel in the "top cargo area" and it will save your plastic window.. i also put one in from the outside as the top folded to prevent the outside to rub against eachother.. its the dirt that is marking it all up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt »</TD></TR><TR><TD CLASS="quote">I also have spare interior pieces, whatever you may need. Just let me know.</TD></TR></TABLE>
hey, thanks for the help
the plastic doesn;t look that bad at all, i regularity help s2k owner to polish the rear plastic, i seem worst.
the best juice i used was mother's clear plastic polish, it's a good combo with a portercable type of buffer.
too bad you are in ohio, or else i can cut those scratches for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">the plastic doesn;t look that bad at all, i regularity help s2k owner to polish the rear plastic, i seem worst.
too bad you are in ohio, or else i can cut those scratches for you.</TD></TR></TABLE>
hey, i apreciate the offer anyway
i have a porter cable 7424, what kind of pad and backing would you recommend to use with clear polish?
.i have a porter cable 7424, what kind of pad and backing would you recommend to use with clear polish?
you can try the regular foam(non-black) but i always use the polishing pad
medium speed, just couple of passes will clear it out good.
oh, if you are using a oversized handle, you might need to remove it to get it in the cabin. try lowering your top just a tad when doing this, this will give you the slightly more room.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote">well we can cut the window out or ride top down always...there i just fixed your problem
wow, what an ingenious solution
</TD></TR></TABLE>wow, what an ingenious solution
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K »</TD></TR><TR><TD CLASS="quote">OMFG yours takes top priority...there's more info than that 1 thread...in the past 2 months i've seen a few myself. So high five to you for looking hard enough. Nobody thinks he is above a simple question..you're just too damn awesome to do a little more work.
wow it didn't work for 1 person...congrats you have 1 opinion. its worked for many others...so has 303. and if you still don't have enough chemicals to make a bomb...try marine plastic cleaner</TD></TR></TABLE>
i mean im not trying to get into it with anyone but it is actually harder to post than search and since when is responding on a forum a priority? i think some people just tell people to search so it builds their posts and makes them feel better
honestly i have not seen a thread on this lately...i saw a hardtop thread that later led into people talking about cleanin the back windows (i was one of them..i asked...im sorry) but if you think its a dumb question then just dont answer.
this isnt against you las2k, people do it all the time, im sure i have. maybe your just having a bad day or something.
honestly i have not seen a thread on this lately...i saw a hardtop thread that later led into people talking about cleanin the back windows (i was one of them..i asked...im sorry) but if you think its a dumb question then just dont answer. this isnt against you las2k, people do it all the time, im sure i have. maybe your just having a bad day or something.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techno Tonis »</TD></TR><TR><TD CLASS="quote">
what ever expletive it.
if you're going to take the time to respond, at least be helpful.
man, i never see this stupid **** on s2ki. if there setup was more general, and less complicated, i would be over there. i hate asking for help on this site, its like pulling teeth. bunch of whining pussies sometimes i swear. LIKE IM INCOVINENCEING YOU FOR ASKING SUCH A SIMPLE QUESTION. gtfo.'
anyway im going with plexus. thanks
edit: p.s. the ******* search on this site is not google! it ******* blows at times! quit telling people to use it, when its simple **** like that!</TD></TR></TABLE>
man i feel you on this one sorry to bring up old **** but
i cant belive ppl take the time to actually post about why you should search instead of just answering the ques. like it bothers them so much to answer a ques
This is the only picture I could find of mine before I tinted it 5%. Luckily it was a raw file so I zoomed in on the window for you. My windows in mint shape and I just polish it with Meguiars.
if you're going to take the time to respond, at least be helpful. </TD></TR></TABLE>
