Honda S2000 Honda S2000
Oil-usage question
Old Nov 19, 2008 | 09:14 AM
GSRGuy17's Avatar
Default Oil-usage question
I have an '03 S2000, all stock. Right around 82k miles. For the past little bit I've noticed a 2-4qt oil usage issue between changes. And I am also noticing a small puff of gray/black smoke coming from the tailpipes at high rpm under load. I know of course that they are related, but is it really a big deal? I know my old GS-R would puff a bit at high rpms and I was told it was fairly normal for an older VTEC Honda.
Old Nov 19, 2008 | 12:52 PM
Boots's Avatar
do a compression test, but most VTEC motors use a little oil.... and AP1's are known to eat a little bit of oil, but i don't know about up to 4 quarts
Old Nov 19, 2008 | 01:21 PM
GSRGuy17's Avatar
Ok, I'll run a compression test. And I'm probably gonna go ahead and have the valves adjusted too.
Old Nov 19, 2008 | 02:16 PM
HondaKyle's Avatar
Mines boosted and I don't even burn half a quart. Before when I was N/A, I would beat on the car more and I still didn't burn really any. Some thing is wrong
Old Nov 19, 2008 | 02:37 PM
Boots's Avatar
yea i had to put a half a quart in today, but in my defense my oil change is only do in 200 miles and i haven't had to do an oil change since april...ive only put like 2500 miles on it in 7 months lol, so half a quart in 7 months aint bad
Old Nov 19, 2008 | 04:28 PM
Black S2K's Avatar
mine eats a lil I wana throw a catch can or crank vents on it so it stops
Old Nov 19, 2008 | 08:31 PM
andre@raw's Avatar
I will do a leak down test to see if it's worn out rings if that cheacks out ok that means it's gonna be the valve seals but with that milage and any high reving motor will use at least 1qt in between oil changes.
Old Nov 19, 2008 | 08:39 PM
GSRGuy17's Avatar
Would the valve seals be easy enough to have replaced (if needed) when I have the valves adjusted?
Old Nov 19, 2008 | 09:34 PM
andre@raw's Avatar
Nope it's not something u could do when adjusting the valves , they could be replaced without removing the cylinder head with the proper tools but it's better of to take the heaad off and send it out to a machine shop and get a full valve job replacing the seals as well.
Old Nov 19, 2008 | 10:30 PM
GSRGuy17's Avatar
Well that isn't gonna be happening anytime soon (lack of $$$), so I'll just tough it out for now. Have the compression checked and go from there.
Old Nov 20, 2008 | 03:16 AM
18psi sohc's Avatar
How long is your OCI? Up to a quart every 1000 miles is ok. More than that would be cause for concern. Check your oil after every fill up and try not to use to much throttle to see if it stop consumption. Lately with gas so cheap I've been using about 2-3 quarts between oil changes since I've been driving a lot harder. I can use up to 4 or 5 depending on how long I decide to go before I change my oil.
Old Nov 20, 2008 | 03:56 AM
eMpAtHy's Avatar
2-4 quarts is a lot of oil. 4 quarts is almost a full oil change.
Old Nov 20, 2008 | 04:58 AM
HondaKyle's Avatar
Just put 4 more quarts in and don't even bother changing your oil!
Old Nov 20, 2008 | 05:24 AM
Black S2K's Avatar
^ lol my friend would do that for like 8 months straight lol his old teg used to eat so much oil he just said **** oil changes and just kept adding oil.
Old Nov 20, 2008 | 05:25 AM
GSRGuy17's Avatar
OCI is 5-6k miles generally. And less throttle? But it's so fun... lol
Old Nov 20, 2008 | 06:04 AM
White Smoke's Avatar
i my honda
Global Mod
What kind of oil are you using?
Old Nov 20, 2008 | 04:23 PM
iam7head's Avatar
have it checked out, sounds like you have some blow by at high rev, could be ring, valve or combination of things
compression and leakdown test in order
Old Nov 20, 2008 | 09:35 PM
riceball777's Avatar
just get the krank vents
my bone stock 60k mile s2000 use to burn 1 quart every 1,000 miles
after the krank vents installe i burn about 1 quart every 3-4,000 miles
my compression test is perfect even before the krank vent install
Old Nov 21, 2008 | 07:14 AM
18psi sohc's Avatar
my compression is at 240+ across all cylinders and I can burn quite a bit if I'm driving hard. Or if I'm babying the car I might not burn any in one OCI.
Old Nov 24, 2008 | 10:54 AM
Urban Camo's Avatar
mine used to use a little over a quart between oil changes when i used regular mobil 1 full syn, switched to the extended performance (p.s. my S has 120k lol) and it barely uses any oil under the same driving conditions, still get the little black smoke at high RPMS but i have a test pipe and catback. just my .02
Old Nov 27, 2008 | 04:35 AM
jewjew bean's Avatar
keep your rpms below 5k and see if that helps. also, only top off your oil when your at the lower level on the dipstick
acuradc292
Mar 7, 2013 05:45 PM
AMG
Sep 28, 2008 11:13 AM
kornerk12
May 1, 2007 12:09 AM
veilsides2000
Apr 1, 2006 04:37 PM
customx_
Mar 18, 2003 05:56 AM
