Honda S2000 Honda S2000
Oil Pressure Problems ?
Old May 24, 2003 | 12:39 AM
vteec's Avatar
Default Oil Pressure Problems ?
Hi,
A friend of mine has just bought an S2000.
Unfortuantely it seems to have a problem......
when starting up it makes a little rattling noise and the oil pressure bulb lights up every now and then......
what do you think guys ?
Old May 25, 2003 | 07:45 PM
ToMMyF20C's Avatar
well with the rattling noise i think it might be a loose screw on your headers or something and the oil pressure bulb light you should probably go to a mechanic and get it checked up
Old May 25, 2003 | 08:01 PM
jerrypeterson's Avatar
Default Re: Oil Pressure Problems ? (vteec)
1. Check oil level.
2. Rev engine is the exhaust blue?
3. Check compression/leak down test.
4. Still nothing out of the ordinary? Check valves for proper clearance.
sounds bad.
Old May 26, 2003 | 10:57 PM
MilanoR's Avatar
Default Re: Oil Pressure Problems ? (jerrypeterson)
Sounds like mine started to act like. I ended up leaing my #4 out. BE CAREFUL man!!!!!
maglites94
May 29, 2012 10:56 AM
DC2TEGGA-GSR
Jan 19, 2006 05:04 PM
kablamo
Jun 18, 2004 06:29 PM
Tchleung
Apr 14, 2004 10:30 AM
vti-R
Jan 31, 2002 05:06 AM
