Honda S2000 Honda S2000
Oil consumption issues...
Old Jan 19, 2008 | 10:44 AM
joey1320's Avatar
Default Oil consumption issues...
DELETED!!!
Modified by joey1320 at 6:24 PM 2/20/2008
Old Jan 19, 2008 | 11:24 AM
kabaroo's Avatar
Default Re: Oil consumption issues... (joey1320)
ouch! i had to add 3 quarts(takes 4) to my car after only 900 miles, but thats my beater.
Figure out how many miles it takes to lose a quart. I was at about 1/2 quart low each fill up when i decided to refresh my B series, but i beat the hell out of that motor.
Old Jan 19, 2008 | 11:54 AM
Alex_G's Avatar
Occupy GDD
Default Re: Oil consumption issues... (kabaroo)
Is it smoking at all by any chance? Could it possibly be leaking from somewhere and not actually consuming oil? If it is consuming that is alot of oil IMO.
Old Jan 19, 2008 | 12:11 PM
dagle's Avatar
Default Re: Oil consumption issues... (Alex_G)
umm was your car cooled down? lol.. sounds to me like it was still warm.. it takes time for oil to settle back into the oil pan... just FYI incase u didnt know
Old Jan 19, 2008 | 01:28 PM
joey1320's Avatar
Default Re: Oil consumption issues... (dagle)
DELETED!!!
Modified by joey1320 at 6:25 PM 2/20/2008
Old Jan 19, 2008 | 01:50 PM
joey1320's Avatar
ok i did quick google and came up with the ap1 service manual. heres the link for anybody who wants to download it. i guess a healthy engine should have about 225psi per cylinder. so i'll be doing a compression test on it tuesday and posting the results.
i'll probably do a "how-to" on the compression test, so that others can see how easy it is to do it.
heres the link:
http://www.maxrev.de/honda-s20...6.htm
Old Jan 19, 2008 | 02:02 PM
Black S2K's Avatar
If your not smokin then your comp ratio should be within spec.
Old Jan 19, 2008 | 02:11 PM
joey1320's Avatar
Default Re: Oil consumption issues... (Black S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">If your not smokin then your comp ratio should be within spec.</TD></TR></TABLE>
thats not always the case... so therefor i'll be doing that test on tuesday.
Modified by joey1320 at 11:23 PM 1/19/2008
Old Jan 19, 2008 | 02:38 PM
dagle's Avatar
yeah that isn't always the case, a leaking headgasket wouldn't smoke that noticably if any at all. (just an example)
it does sound like a leak somewhere though to be honest, thats a pretty substantial amount of oil to be missing without any adverse effects on power. but of course a compression check will help straighten some of it out.
good luck
Old Jan 19, 2008 | 03:16 PM
43!'s Avatar
43!
You need to do compression & leak down test. If compression is within spec, it's probably the valve seals.
Old Jan 19, 2008 | 07:24 PM
Black S2K's Avatar
Default Re: Oil consumption issues... (43!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 43! &raquo;</TD></TR><TR><TD CLASS="quote">You need to do compression & leak down test. If compression is within spec, it's probably the valve seals.</TD></TR></TABLE>
Either way he would still be smoking sinse hes not I think hes fine when it comes to those two things. It wouldnt hurt to check but im sure his rings and seals are fine.
Old Jan 19, 2008 | 09:19 PM
negcamber's Avatar
Recall that most early ap1's use oil at a faster rate than the other model years. Just a quirk of the car. Mine goes through about 1-1.5 quarts per 3000miles.
Old Jan 19, 2008 | 10:33 PM
b e b's Avatar
Default Re: (negcamber)
Dont rely on your oil light. When my filter crapped out I didnt get a warning until my dipstick was bone dry and the light flashed once and disappeared.
Old Jan 20, 2008 | 12:15 AM
LeGeND4LiFe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negcamber &raquo;</TD></TR><TR><TD CLASS="quote">Recall that most early ap1's use oil at a faster rate than the other model years. Just a quirk of the car. Mine goes through about 1-1.5 quarts per 3000miles. </TD></TR></TABLE>
Which years would those early AP1s be?
jonyi27
Apr 21, 2014 11:55 AM
Nicks95GSR
Sep 28, 2007 10:54 AM
HoUTX98GSR
Jun 16, 2005 06:47 PM
chillax
Aug 11, 2003 04:32 AM
