Honda S2000 Honda S2000
which offset / size would u choose...
Old May 16, 2007 | 05:00 PM
J.nguyen's Avatar
Default which offset / size would u choose...
16 x 7.0 +40 5h x 114.3 (would this work if i got all 4.. no rolling fenders and moderate to low drop..)
17 x 7.5 +35/+45 5h x 114.3
17 x 8.5 +35/+40/+50 5h x 114.3
18 x 7.5 +35/+45/+48 5h x 114.3
18 x 8.0 +35/+42/+48 5h x 114.3
18 x 9.0 +35/+45/+48/+50 5h x 114.3
Modified by J.nguyen at 6:53 PM 5/16/2007
Old May 16, 2007 | 05:06 PM
LAS2K's Avatar
Default Re: which offset / size would u choose... (J.nguyen)
Can you post some more sizes and offsets? I dont think there are enough to choose from.
ARE YOU JOKING comeon common sense would cross out half of that crap why waste yours/our time?
17 x 7.5 +45
17 x 8.5 +40
Old May 16, 2007 | 05:14 PM
J.nguyen's Avatar
Default Re: which offset / size would u choose... (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">Can you post some more sizes and offsets? I dont think there are enough to choose from.
17 x 7.5 +45
17 x 8.5 +40</TD></TR></TABLE>
sorry just copy and pasted didnt have time to edit em out.
but thanks for the choices. guess tahts the best choice
Old May 16, 2007 | 05:20 PM
LAS2K's Avatar
Its my opinion of best choice. All depends on what look, or function you are going for. What is your goal?
p.s. your old DC2 is beautiful.
Old May 16, 2007 | 05:33 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">Its my opinion of best choice. All depends on what look, or function you are going for. What is your goal?
p.s. your old DC2 is beautiful. </TD></TR></TABLE>
overall best of the best function / form
aha thanks. damn everytime someone says something about my old car, makes me miss it even more.. ahh but s2k outweights it all
Old May 16, 2007 | 05:38 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
17 x 7.5 +45
17 x 8.5 +40
or even +35 rear its only a 8.5 rim
Old May 16, 2007 | 05:41 PM
J.nguyen's Avatar
Default Re: which offset / size would u choose... (S@nt0s)
ic thanks
i wanted 17 x9 +45 R
but they dont have it =\
Old May 16, 2007 | 05:44 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.nguyen &raquo;</TD></TR><TR><TD CLASS="quote">ic thanks
but they dont have it =\</TD></TR></TABLE>
with teh 8.5's on a +35 offset it will give the same "look" as the +45 x9's
Old May 16, 2007 | 05:45 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">
with teh 8.5's on a +35 offset it will give the same "look" as the +45 x9's</TD></TR></TABLE>
oic
35 or 40 for rear.. hmmm
LAS2K's Avatar
true yeah that sounds better actually. What wheels and how much of a drop do you plan?
Old May 16, 2007 | 05:52 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">true yeah that sounds better actually. What wheels and how much of a drop do you plan? </TD></TR></TABLE>
for right now, its on espelir springs.. wont get coil overs for another year.. ahah so my drop is moderate
also double check.. tire size should be :205/45/17 F and 235/40/17 R right?
Old May 16, 2007 | 05:54 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
215x45 front 245x40 rear...
Old May 16, 2007 | 05:55 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">215x45 front 245x40 rear... </TD></TR></TABLE>
even if i went with the 35+ offset in rear?
ic thanks.. i was just using this as my guide: http://www.s2ki.com/forums/ind...42793
dunno about s2k's but is falken ziex tires good with them?
Old May 16, 2007 | 06:00 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
ic thanks.. i was just using this as my guide: http://www.s2ki.com/forums/ind...42793</TD></TR></TABLE>
yes even with teh +35 rear.. roll the fenders and a lil camber and your set
Old May 16, 2007 | 09:46 PM
- BSeRiouS -'s Avatar
okay, let the wheel jock through
Of these sizes, your best bet is to run (clearance) would be:
17 x 7.5 +45 5h x 114.3
17 x 8.5 +50 5h x 114.3
You can sucessfully run stock AP2 tire sizes of 245/215 combo with this set up
255 is also do-able too, but you will rub if you hit deep dips or crevices in the street with non rolled fenders. other than that, daily driving is perf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.nguyen &raquo;</TD></TR><TR><TD CLASS="quote">16 x 7.0 +40 5h x 114.3 (would this work if i got all 4.. no rolling fenders and moderate to low drop..)?</TD></TR></TABLE>
Stick with traditional staggered set ups. It will work but your car will drive like *** especially running 7's all around. You can get away with running staggered tire set ups but I say squash this set up:
with the 8.5's on a +35 offset it will give the same "look" as the +45 x9's</TD></TR></TABLE>
yes yes, but the 8.5 +35 is way more aggressive than a 9+45. If running this set up, It should stick out about 1/8 inch more than a 9+45.
the closest set up that come's close to a 9+45 is an 8.5 +40 with a differenece of 1 mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.nguyen &raquo;</TD></TR><TR><TD CLASS="quote">for right now, its on espelir springs.. wont get coil overs for another year.. ahah so my drop is moderate
also double check.. tire size should be :205/45/17 F and 235/40/17 R right?</TD></TR></TABLE>
If running a 9+45, on non rolled fenders, 235-40-17 is your best bet (that is if your tucking) If you have finger gaps, 245-40 would be better but you will have your occasional rubs.
dunno about s2k's but is falken ziex tires good with them? </TD></TR></TABLE>
1) Don't use the wheel fitment guide. Its been way outdated. Talk to me If you need help
2) Falken Ziex are sorry *** tires lol. RT615's are best, or if you can find the OG, RT215's like me. If not, settle for Falken FK452's.
Let me know
Old May 16, 2007 | 10:38 PM
J.nguyen's Avatar
Default Re: which offset / size would u choose... (OBSeRiouSo)
Damn grip of info, thanks man
Old May 16, 2007 | 11:49 PM
Ohh yes. I have a pair of NSX Spec/BBK Spec Regamasters for sale for the s2000
Only a pair though. Check the FS forum.
17x8 +35. Either run a 205-45-17 stretch on that 8" on non rolled fenders or a 215-45 with rolled front fenders
Old May 17, 2007 | 09:07 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBSeRiouSo &raquo;</TD></TR><TR><TD CLASS="quote">
yes i know its more aggressive but he can still do with with the +35 235x40's with some roll, or 245's with roll and camber...
Old May 17, 2007 | 09:42 AM
Francesco's Avatar
thats what I have, and its a tight fit. I have to roll my rears again, and im only running a 245/40 back there.
Old May 17, 2007 | 11:07 AM
S2K1985's Avatar
yo nguyen you live in mira mesa right?? your friends with Justin Z. anyways do you know any hook up for rims or exhaust system?
Old May 17, 2007 | 11:53 AM
J.nguyen's Avatar
Default Re: which offset / size would u choose... (S2K1985)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K1985 &raquo;</TD></TR><TR><TD CLASS="quote">yo nguyen you live in mira mesa right?? your friends with Justin Z. anyways do you know any hook up for rims or exhaust system? </TD></TR></TABLE>
yeah
rims or exhaust system for an S2k? haha naa im lookin for rims and **** too
Old May 17, 2007 | 12:40 PM
S2K1985's Avatar
oohh.. iight i thought you might know any hook ups... well iight ill just go to panda garage they might have something there..hehe.. nice meeting you though..
Old May 17, 2007 | 05:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">yes i know its more aggressive but he can still do with with the +35 235x40's with some roll, or 245's with roll and camber...</TD></TR></TABLE>
of course of course. Im not saying that your wrong
You know your shiet. Im just adding additional info you forgot to say
Old May 17, 2007 | 05:44 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
You know your shiet. Im just adding additional info you forgot to say </TD></TR></TABLE>
course homie we are both jsut trying to be understood...
Old May 17, 2007 | 05:49 PM
Word
PURP
Nov 3, 2009 09:37 AM
743 Stunna
May 21, 2008 01:29 PM
OPTION2ek V.2
Northern California (Sales)
Feb 26, 2008 07:20 PM
ley
Honda Civic (2001 - 2005)
12
Feb 28, 2007 08:36 PM
Integra21
Jun 23, 2005 09:18 PM
