Honda S2000 Honda S2000
NSX front end conversion
Old Feb 14, 2003 | 06:57 AM
mojo6940's Avatar
Default NSX front end conversion
I might be buying a 93 NSX wrecked in the front at one of the local salvage pools, and I was wondering if the new 03 front clip would bolt on with no major modifications,(drilling holes, bending metal, etc.) I would hate to buy the 03 front cap and have to modify $6g's in parts.
Thanks,
Jonathan
Old Feb 14, 2003 | 07:41 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: NSX front end conversion (mojo6940)
Then don't buy it, because that's about what you'd be looking at. If you replace the front clip, you will need to replace the headlights, hood, and fenders. It's not a bolt-on swap.
Old Feb 14, 2003 | 09:42 AM
mojo6940's Avatar
Default Re: NSX front end conversion (nsxtasy)
When I say modify i mean like trimming fenders, redrilling latches and stuff like that. I guess I should have been more specific. Here goes: Does the door on the 92 follow the same line as the 2003 fender. Does the hood have the same width? As long as the door fits the fender line, i wouldn't mind modifying anything else to fit. Replacing all the parts you mentioned means exactly what I said in the title... FRONT END CONVERSION.
Old Feb 14, 2003 | 10:01 AM
ak's Avatar
ak
http://www.nsxprime.com/FAQ/Accessories/bodykits.htm here's some info but reallly, you should do a search on http://www.nsxprime.com forum section. This has been talked about several times.
Old Feb 14, 2003 | 01:37 PM
nsxtasy's Avatar
H-T Order of Merit
No, you don't have to replace the doors; the fenders are different because of the space that they allow for the headlights at the front of the fenders, no change at the rear.
The hood has to be replaced. The width of the rear of the hood is the same, but the cutouts for the headlights are an entirely different shape and width, and you would have to buy a new hood.
I'm not trying to be difficult or give you a hard time. I'm just pointing out that you would have to replace the parts that I mentioned, and $6K is probably a pretty good estimate on what they will run you.
Keep in mind that you can probably get (relatively) inexpensive used body parts for the '91-01 front end pretty easily from ERZ Motors in New York, but for the '02-03 front end, you will have to buy new.
If you don't care much about the looks of the front end either way, and you want the newer one primarily because of the HID lights, it's also worth noting that there's a nice HID kit specifically for the '91-01 NSX available for $580 from Science of Speed.
Old Feb 14, 2003 | 08:16 PM
mojo6940's Avatar
Thanks for the info!
Jonathan
sk8board{Pete}
Honda Civic (2001 - 2005)
Feb 5, 2013 12:07 PM
augie1209
Oct 24, 2012 06:35 PM
racerx510
Aug 5, 2012 12:33 AM
MauricioJDM
Aug 21, 2011 01:35 AM
HondaCrazy
15
Oct 6, 2004 09:14 AM
