Honda S2000 Honda S2000
Missed shift
Old Nov 19, 2006 | 10:10 AM
327da9's Avatar
Default Missed shift
Crap I was driving home late last night and while in 3rd at redline, i go to shift to 4th but instead land in second. I never let clutch all the way out and saw the rpms go up to the high 7k's. My question is, does the tach light up red like when you hit 8k during an overrev? If it does, how accurate is the tach, since i never saw hit light up red at 8k am i ok on this?
Old Nov 19, 2006 | 10:19 AM
Newkdog's Avatar
I miss Andrea.
What car were you in?
Old Nov 19, 2006 | 10:21 AM
327da9's Avatar
Default Re: Missed shift (327da9)
My s2k, its an 06.
Old Nov 19, 2006 | 10:51 AM
LAS2K's Avatar
you are probably okay but to be safe i would get a compression check.
Old Nov 19, 2006 | 11:55 AM
AlphaKennyWun's Avatar
Default Re: Missed shift (LAS2K)
When the rpm goes past 8k the red bars on the ap2 stock tach will blink rapidly. If you only went up to high 7ks I wouldnt even think twice about it.
Old Nov 19, 2006 | 12:34 PM
Francesco's Avatar
my car sees redline everyday, your ok.
Old Nov 19, 2006 | 01:08 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
u can rev 9k all day long dont worry
Old Nov 19, 2006 | 01:16 PM
327da9's Avatar
Default Re: (RED_90TEG)
I hit redline all the time. The difference this time is i down shifted at the top of 3rd to 2nd instead of 4th.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2K.Chris &raquo;</TD></TR><TR><TD CLASS="quote">When the rpm goes past 8k the red bars on the ap2 stock tach will blink rapidly. If you only went up to high 7ks I wouldnt even think twice about it. </TD></TR></TABLE>
After reading a bunch of old posts on this, im guessing my clutch must have been slipping like crazy since i never fully disengaged the clutch when i dropped it in 2nd keeping me from launching the rpms to 10+k. Saved by a slipping clutch
My 06 gear box is so goddamn notchy even after its warmed up that it makes it hard to do smooth shifts I guess i better have the dealer look at that before another shifting mishap
Old Nov 19, 2006 | 06:09 PM
Mike_C's Avatar
Default Re: (Newk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newk &raquo;</TD></TR><TR><TD CLASS="quote">What car were you in?</TD></TR></TABLE>
why would he post in the s2000 froum if it was one of his other cars? get out of this forum, you have nothing to contribute.
OP, you're fine.
Old Nov 19, 2006 | 07:03 PM
evil vapor's Avatar
Default Re: (Mike C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">
OP, you're fine.</TD></TR></TABLE>
lol!
I know the s2000 tranny, ap1 or ap2, does not fare well with poor shifting technique. If you grind gears often/seldom, the damage could already be done.
Old Nov 19, 2006 | 07:53 PM
327da9's Avatar
Default Re: (evil vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil vapor &raquo;</TD></TR><TR><TD CLASS="quote">
lol!
I bought the car brand new hoping that the notchiness was just from being new. A few thousand miles later, it never went away
Old Nov 19, 2006 | 09:38 PM
evil vapor's Avatar
Default Re: (327da9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 327da9 &raquo;</TD></TR><TR><TD CLASS="quote">
I bought the car brand new hoping that the notchiness was just from being new. A few thousand miles later, it never went away </TD></TR></TABLE>
when was the last trans fluid change?
Old Nov 20, 2006 | 01:12 AM
iam7head's Avatar
when was the last trans fluid change?</TD></TR></TABLE>
most of the time it's just used tranny juice, but if you haven't grease the shifter for a while, check it out.
if you think you misshifted your ride, have it compression checked out, if the reading is bad pop the valve cover to check for retainer damage.
I inspected coupld of overrev'ed S before, it's better be safe and sorry.
PM me if you need a check up done, I been doing alot of testing/wrenching for SOCAL S lately
Old Nov 20, 2006 | 12:44 PM
Mr. Projekt's Avatar
* B A N N E D *
The 2.2L is good to 8800rpms. You're fine.
The notchyness in my tranny went away after switching to Royal Purple tranny fluid. Now it's silky smooth.
Old Nov 20, 2006 | 05:50 PM
327da9's Avatar
Default Re: (iam7head)
iam7head,
How bad were the over-rev'd S's that you inspected? Any of them get away unscathed? Thanks for the offer to inspect it, but im up in norcal.
The car has 2k miles on it, its still the original fluid. Its so notch between the gates its hard to get clean shifts.
Old Nov 20, 2006 | 07:09 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 327da9 &raquo;</TD></TR><TR><TD CLASS="quote">iam7head,
The car has 2k miles on it, its still the original fluid. Its so notch between the gates its hard to get clean shifts. </TD></TR></TABLE>
Look into Redline, Royal Purple, or GM Synchromesh FM tranny fluids at your next oil change.
Old Nov 20, 2006 | 10:44 PM
evil vapor's Avatar
mileage isn't always a factor in fluid changes. If the car has been sitting around, the fluid would need changing out too.
Old Nov 21, 2006 | 01:22 PM
iam7head's Avatar
i checked 3 overrev'ed S, all three of them are fine, first two were ap1's with more mile, the 03 pulled 200psi across the board, the 01 pulled 200/195 and the last 06 pulled 215(with 5k on the odo)
i checked the retainer and they are fine
well, the most of the time it just need a tranny fluid change, there's a NEW version of the honda mtf, not sure how good is the new one tho. I am using GMSMFM
Old Nov 22, 2006 | 11:22 AM
RC_SKUBY's Avatar
Default Re: Missed shift (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">my car sees redline everyday, your ok.</TD></TR></TABLE>
x2
SHIFKU(EF9 HOPE FUL)
Oct 16, 2005 09:56 PM
SleepnCiViC
Dec 8, 2003 07:34 AM
Behan
May 16, 2003 09:18 AM
slash00R
Oct 4, 2001 11:35 AM
