Honda S2000 Honda S2000
jdm engine?
Old Dec 18, 2003 | 01:20 PM
veilsides2000's Avatar
Default jdm engine?
Any of you guys have any pictures or links to a s2000 jdm engine. thanks
Old Dec 21, 2003 | 01:23 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: jdm engine? (veilsides2000)
Same as USDM.
Old Dec 21, 2003 | 06:59 PM
CD5sam's Avatar
Default Re: jdm engine? (91 Teg)
the jdm f20c has slightly more compression producing an extra ~7 hp. they were able to make the compression higher because in japan they have access to higher octane gas.
Old Dec 21, 2003 | 07:20 PM
Default Re: jdm engine? (CD5sam)
where in fairfax do you live?
Old Dec 21, 2003 | 09:35 PM
profpin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD5sam &raquo;</TD></TR><TR><TD CLASS="quote">the jdm f20c has slightly more compression producing an extra ~7 hp. they were able to make the compression higher because in japan they have access to higher octane gas.</TD></TR></TABLE>
where did you get that info from....
i know that all the jdm honda motors (except for the f20c) has a higher comp than the us counterparts but, as far as the f20c goes, the specs seems to be the same......i think the ecu is different though, cuz when they mod the s2k in japan , it seems like they have to use some sort of speed limit cutter....(j's racing, amuse, feel's)
here sre the specs for the s2000 and the s2000 type v in my hyper rev mag.....
(kw[ps]/rpm) 184[250]/8300
(N.m[kg.m]/rpm) 218[22.2]/7500
if you do the math the power is equal to the usdm engine.....
Old Dec 23, 2003 | 03:13 PM
CD5sam's Avatar
Default Re: jdm engine? (profpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by profpin &raquo;</TD></TR><TR><TD CLASS="quote">
if you do the math the power is equal to the usdm engine.....</TD></TR></TABLE>
http://forums.s2ki.com/forums/...+f20c
Old Dec 24, 2003 | 03:34 PM
S2KandSTi's Avatar
250ps is equal to 247HP making it 247 HP. It has an 11.7 compression ratio which is created by higher comp pistons and a head gasket.
Old Dec 24, 2003 | 03:46 PM
Razor's Avatar
Default Re: (S2KandSTi)
werd
Old Jun 19, 2006 | 11:22 PM
douglas_be's Avatar
Default Re: (Razor)
Does anyone have the partnumbers of these pistons and headgasket ?
Thanks
Douglas
Old Jun 20, 2006 | 09:22 AM
Cone's Avatar
Default Re: (douglas_be)
http://www.aj-racing.com They can get the JDM pistons. I *think* the headgaskets are the same.
Convert
18
Aug 31, 2007 07:57 AM
krucial
Honda S2000
38
Jan 28, 2006 07:25 PM
denisfern
Honda S2000
28
May 5, 2005 08:01 PM
vtecjj
May 25, 2004 06:37 PM
viCeVerSa
Nov 7, 2002 01:48 PM
