Honda S2000 Honda S2000
JDM S2000 Engine
Old Apr 18, 2005 | 07:38 PM
denisfern's Avatar
Default JDM S2000 Engine
is there a diference between the JDM s2000 engine and the USDM ? anyone psl ?
Old Apr 18, 2005 | 07:47 PM
R0cko's Avatar
I cant find a difference
Old Apr 18, 2005 | 08:13 PM
97ShLude's Avatar
I think that the ap2 in japan got the 2.0 liter instead of the 2.2 liter that was offered here in the states. Other than that I don't think that there are any differences power or tranny wise between the japanese and u.s. motors.
Old Apr 18, 2005 | 08:31 PM
Nishant's Avatar
Default Re: (97ShLude)
jdm engine has higher compression...forget the #'s right now
Old Apr 18, 2005 | 10:01 PM
MAD ITR 55's Avatar
Default Re: (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">jdm engine has higher compression...forget the #'s right now</TD></TR></TABLE>
If I remember correctly I think it has 250 hp due to the higher compression....
Old Apr 19, 2005 | 04:20 AM
Nishant's Avatar
Default Re: (MAD ITR 55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD ITR 55 &raquo;</TD></TR><TR><TD CLASS="quote">
If I remember correctly I think it has 250 hp due to the higher compression....</TD></TR></TABLE>
i think its 2 more bhp, not 10. this is due to japan having higher octane gas everywhere
Old Apr 19, 2005 | 05:16 AM
Francesco's Avatar
i think its 2 more bhp, not 10. this is due to japan having higher octane gas everywhere</TD></TR></TABLE>
damn higher octane...
can't you buy race gas in Japan on the street pumps?
Old Apr 19, 2005 | 08:32 AM
papa5murf's Avatar
Default Re: (Francesco)
jdm f20c has a compression of 11.1:1, and it's got like 243hp or something like that.....
Old Apr 19, 2005 | 08:37 AM
denisfern's Avatar
so the JDM tranny has the same specs as the USDM ???
Old Apr 19, 2005 | 09:03 AM
papa5murf's Avatar
Default Re: (denisfern)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denisfern &raquo;</TD></TR><TR><TD CLASS="quote">so the JDM tranny has the same specs as the USDM ???</TD></TR></TABLE>
yes
Old Apr 19, 2005 | 09:58 AM
SKRacer's Avatar
Their gas has higher octane but is more crude than our gas.
Old Apr 19, 2005 | 10:00 AM
hypnosisracing's Avatar
Default Re: (SKRacer)
Yup...as someone said before too, the JDM AP2 still has a 2.0, where as the usdm got the newer 2.2, transmissions are obviously different between those 2 engines, but i believe that they are the same spec as the AP1 2.0 and the AP2 2.0.
Old Apr 19, 2005 | 11:45 AM
AdamQ3B85's Avatar
Default Re: (03s2kblue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">jdm f20c has a compression of 11.1:1, and it's got like 243hp or something like that..... </TD></TR></TABLE>
I always thought the JDM F20C had a compression of 11.5:1....
Old Apr 19, 2005 | 12:08 PM
boszyen's Avatar
Default Re: (AdamQ3B85)
it's actually 11.7:1
Old Apr 19, 2005 | 12:14 PM
RyanEJ8's Avatar
Default Re: (boszyen)
No it's 13.725:1
Old Apr 19, 2005 | 12:18 PM
^^^ Yup...by way of a different head gasket from what i've read.
Old Apr 19, 2005 | 12:22 PM
Nishant's Avatar
Default Re: (hypnosisracing)
so whats the real jdm compression
AdamQ3B85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boszyen &raquo;</TD></TR><TR><TD CLASS="quote">it's actually 11.7:1
You seem to be correct. This is what I get from the Honda.co.jp
" Engine Engine type F20C
Valve gear DOHC chain & gear drive
Inhalation 2 exhaust 2
Entire aerodynamic volume displacement (cm3) 1,997
Inside diameter x distance (mm) 87.0×84.0
Compression ratio 11.7
Fuel feeder type Electrically controlled gasoline injection system
(HONDA PGM-FI)
Use fuel type Unleaded premium gasoline
Fuel tank capacity (L) 50
Lubricating system Force system
Efficiency The highest output
(KW [ PS ] /rpm) * 184[250]/8,300
Largest torque
(N * m [ kg * m ] /rpm) * 218[22.2]/7,500
Old Apr 19, 2005 | 12:36 PM
papa5murf's Avatar
i stand corrected... jsut checked honda of japan.. and it's 11.7:1 compression ratio
Old Apr 19, 2005 | 09:16 PM
MAD ITR 55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamQ3B85 &raquo;</TD></TR><TR><TD CLASS="quote">
Is PS same as HP?? Meaning it has 250hp??
Old Apr 20, 2005 | 06:17 PM
AdamQ3B85's Avatar
Is PS same as HP?? Meaning it has 250hp?? </TD></TR></TABLE>
250 Ps would be something like 246-247 Hp... I do not know the exact convertion.
Old Apr 20, 2005 | 06:32 PM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKRacer &raquo;</TD></TR><TR><TD CLASS="quote">Their gas has higher octane but is more crude than our gas.</TD></TR></TABLE>
really? so what octanes are they able to get there? For some reason I was always under the impression that high octane wasn't as available as it is here in the states.
Old Apr 21, 2005 | 12:22 PM
eludedude's Avatar
its kinda dumb when all s2000 engines are made in japan. so hence, even though there is a difference between jdm and usdm, all are made in japan.
Old Apr 24, 2005 | 12:36 PM
Default Re: (eludedude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eludedude &raquo;</TD></TR><TR><TD CLASS="quote">its kinda dumb when all s2000 engines are made in japan. so hence, even though there is a difference between jdm and usdm, all are made in japan.</TD></TR></TABLE>
silly indeed
Old Apr 27, 2005 | 05:54 AM
Default Re: (ScreaminTeg)
Not really that silly...look at the FLOCK of people that go for Bseries motors and stuff from japan, now imagine the reverse, if they release a motor in the U.S. thats different (and bigger) than the one in japan, maybe they can get some reverse flow of swap demand, with the amount of horrid drivers here, japan should have a buffet full of 2.2's waiting to ship...i mean i doubt that was the reason it was done, but it makes since in this aspect as well as whatever engineering purpose there was for it.
