Honda S2000 Honda S2000
Intake Check Engine Light
Old May 10, 2007 | 02:59 PM
  #26
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (wrice4)
Did you check the two little vacumm lines going into the EVAP solenoid?
Old May 10, 2007 | 04:22 PM
  #27
b20integrapower's Avatar
Default Re: (Mr. Projekt)
give us a code, maybe we could help you then.
Old May 10, 2007 | 04:38 PM
  #28
* B A N N E D *
Default Re: (b20integrapower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">give us a code, maybe we could help you then.
And the dealer should have pulled the code and service it, not just erase it. I smelled BS, so I didn't even bother.
Old May 10, 2007 | 08:14 PM
  #29
s2000 mf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrice4 &raquo;</TD></TR><TR><TD CLASS="quote">ya well everything is plugged in right, checked like 100 times, and i have reset my ecu like a 100 also, i called aem help and they have no idea what is wrong. ANy help please.</TD></TR></TABLE>
Well next time the CEL pops up dont reset your ecu and go to autozone or kragen and get the code pulled for free.
Old May 11, 2007 | 08:15 AM
  #30
wrice4's Avatar
ok well im going back to honda today so ill get the exact code for you guys if you dont mind helping
Old May 11, 2007 | 02:21 PM
  #31
wrice4's Avatar
the code is .............PO411............????
Old May 11, 2007 | 02:31 PM
  #32
* B A N N E D *
P0411 is Secondary Air Injection Incorrect Flow. You have the vacumm lines to the EVAP solenoid reversed.
Old May 11, 2007 | 02:41 PM
  #33
s2000 mf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">P0411 is Secondary Air Injection Incorrect Flow. You have the vacumm lines to the EVAP solenoid reversed.</TD></TR></TABLE>
I agree. Or your sensor is unpluged.
Old May 11, 2007 | 04:08 PM
  #34
wrice4's Avatar
i have already switch the lines, and checked the sensor...and AEM does not know what is wrong, neither does honda
Old May 12, 2007 | 07:17 AM
  #35
Shy_GuyAP1's Avatar
Did you reset the ECU?
When ever I put stuff like that on my civic, just disconnect the battery before you go to bed and reconnect when you get up, drive conservatively for a few days. It should fix it.
Old May 12, 2007 | 09:39 AM
  #36
wrice4's Avatar
well i did that, so we are gonna wait to see what the light does, its off right now
HondaDanny06
Honda Civic (2006 - 2015)
28
Apr 5, 2008 01:26 PM
bcaccord01
Mar 13, 2008 07:15 AM
95-Accord-EX
Jan 26, 2008 08:50 PM
rz514
Jul 11, 2006 10:33 AM
DrewkCarrigan
Honda S2000
Mar 12, 2006 04:46 PM
