Honda S2000 Honda S2000
I need help :(
Old Nov 18, 2010 | 10:32 AM
vietdragontekx's Avatar
Default I need help :(
I need help . This morning i woke up and started my s2000 which i bought yesterday. It started fine and i open up engine bay n rev the motor a little. After a few minute the motor seem to rev by itself at 3000 rpm and stayed there. I got scare n shut it off. Now when i crank it up, it wont start at all. It just keep cranking. crank very slow and after 2 or three time it dead this is not a good start with my new s2000. could it be the battery? all the light turn on etc.
Old Nov 18, 2010 | 10:38 AM
bigmacnfries's Avatar
Default Re: I need help :(
have you let the seller know? or asked them? best place to start by the sound of it.
Old Nov 18, 2010 | 10:40 AM
i told the seller he said he don't know the car run fine and started fine yesterday when i bought it. he said he never had that problem before
Old Nov 18, 2010 | 10:41 AM
camoy's Avatar
What most likely has happened is you shut of the motor when it was warming up and running rich, thus flooding it. Then as you tried to start it again and again you have drawn the battery down low enough that the car will not catch and start.
Take your plugs out and let the thing sit for about 30 minutes, then put it back together, get some jumper cables and jump the car to start it and see if that doesn't work.
Don't rev the car needlessly not as cool as you think and not good for the motor to rev without a load.
And get a new battery as you most likely have killed the one you have or it was already weak to begin with.
Old Nov 18, 2010 | 10:58 AM
thanks i wil ltry that
Old Nov 18, 2010 | 12:26 PM
fingers crossed you flooded it - anything else could be baaaaaad.
Old Nov 18, 2010 | 01:51 PM
i fixed it ignition coil fuse is blown for some reason. after replace still didn't start, remove the AEM ems management and reconnect stock ecu and it fire on. reconnect aem ems management and it turn right on. thx god it was nothing big
thanks guys
Old Nov 18, 2010 | 03:50 PM
phew.
now, enjoy!
dthor68
Honda CR-V & Element
May 4, 2018 10:33 AM
kevinhughes13
Oct 6, 2014 12:28 AM
nike306
Aug 6, 2012 08:59 AM
track_assassin
Dec 16, 2005 10:43 AM
TreyGSR
Mar 4, 2005 02:45 PM
