Honda S2000 Honda S2000
how to remove broken gas cap?
Old Sep 21, 2007 | 11:43 AM
J.nguyen's Avatar
Default how to remove broken gas cap?
i took a stupid advice b/c i had a CEL, even though i knew it couldnt be the fix, b/c p1456 & p1457 are different things, i said it coudlnt hurt to try.. so i did this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthondatune &raquo;</TD></TR><TR><TD CLASS="quote"> I got this code the first few weeks after I bought my S.. FREAKED me out.
The root cause - morons filling my gas tank and not closing the cap properly.
My gas cap seems to screw-in halfway, then clicks a few times.. however there's still almost 2 full turns left until it's fully closed.
Push-in Firmly, and turn your gas cap at the same time.
There's a trick to it, so the cap seals completely before clicking.
I know some of you say it's not the cap, but it happened to me.</TD></TR></TABLE>
and im not even sure if my gas cap is closed all the way or not, but i just know it broke on me, saw a lil white piece come off, and now it just spins, it wont open or close if it isnt closed all the way..
how do i open the gas cap ? who else sells oem replacements rather then the dealer?
Old Sep 21, 2007 | 11:47 AM
papa5murf's Avatar
Default Re: how to remove broken gas cap? (J.nguyen)
Hummm, take a picture maybe so we can see?
Are you saying it just spins and spins and spins now?
Old Sep 21, 2007 | 11:49 AM
J.nguyen's Avatar
Default Re: how to remove broken gas cap? (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">Hummm, take a picture maybe so we can see?
Are you saying it just spins and spins and spins now?</TD></TR></TABLE>
yes just spins 24/7
Old Sep 21, 2007 | 12:02 PM
SOKDO's Avatar
Gas is over-rated anyways. Now nobody can put sugar in your tank.
On a serious note... you can always drill into it... not in the middle though because then flakes can go into your gas tank. Drill one on opposite sides and put a couple screw drivers in to hold it and turn. Might work might not. Just a suggestion.
If that doesn't work... just use a lil saw to start breaking it apart and i'm sure you will get to the point where you can put a big plier over it and turn it.
Old Sep 21, 2007 | 01:44 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: how to remove broken gas cap? (sokdo321)
so its spining???
channel locks around the base....
Old Sep 21, 2007 | 02:09 PM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: how to remove broken gas cap? (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">so its spining???
channel locks around the base....</TD></TR></TABLE>
good call, i was going to suggest pliers and a flat head and just work that bitch... i would not suggest any cutting or drilling... and **** that gets into your tank is bad news
Old Sep 21, 2007 | 02:12 PM
J.nguyen's Avatar
this thing right, i got alot of diff kinda chan. locks.. more then one used?
Old Sep 21, 2007 | 02:47 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
thats your best be with the angle you have to work with
Old Sep 21, 2007 | 03:30 PM
WowOzYouRock's Avatar
HAHAHAHAHAHAHAHAHAHAH...
Old Sep 21, 2007 | 04:02 PM
iloveADOBO's Avatar
Default Re: how to remove broken gas cap? (WowOzYouRock)
i dont really think drilling will hurt it - the gas flap itself is just that - a flap that must be depressed - but i'd save that for the last resort - channel locks ( regardless of what you use - be careful of the threads on that neck)
good luck j.nguyen
Old Sep 21, 2007 | 04:52 PM
S2KILLA's Avatar
Default Re: how to remove broken gas cap? (iloveADOBO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WowOzYouRock &raquo;</TD></TR><TR><TD CLASS="quote">HAHAHAHAHAHAHAHAHAHAH... </TD></TR></TABLE>
thats kinda dick... but made me laugh...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iloveADOBO &raquo;</TD></TR><TR><TD CLASS="quote">i dont really think drilling will hurt it - the gas flap itself is just that - a flap that must be depressed - but i'd save that for the last resort - channel locks ( regardless of what you use - be careful of the threads on that neck)
good luck j.nguyen </TD></TR></TABLE>
because u didnt think... hmm lets see, what happens if he drills into metal by accident, metal gets hot, goes into gas and:
Old Sep 21, 2007 | 06:31 PM
dagle's Avatar
Default Re: how to remove broken gas cap? (S2KILLA)
have u tried piercing it with a knife to make holes that u can use pliars or something to turn the gas cap with? like 2 parallel slits that will let your pliars in to pinch/turn the gascap out. just be very careful you're piercing it and not cracking it.
if u can't get through with a knife + human force.
hold the knife like a serial killer
put the point on the gascap + tap with hammer until u poke through
if for some reason u still cant turn it out, well u have a hole that u can now access to rip the rest of the gas cap out. good luck yO
Old Sep 21, 2007 | 06:32 PM
LAS2K's Avatar
Default Re: how to remove broken gas cap? (dagle)
If you HAVE to drill, disconnect the fuel line.
Old Sep 21, 2007 | 06:35 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: how to remove broken gas cap? (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">If you HAVE to drill, disconnect the fuel line. </TD></TR></TABLE>
DONT DRILL IT
if u wanna use the backyard mechanic way.. a flathead and a hammer will do the trick.....
Old Sep 21, 2007 | 07:31 PM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">
good call, i was going to suggest pliers and a flat head and just work that bitch... i would not suggest any cutting or drilling... and **** that gets into your tank is bad news</TD></TR></TABLE>
Theirs a flap over the inlet, nothing will get in.
Old Sep 21, 2007 | 08:26 PM
iloveADOBO's Avatar
because u didnt think... hmm lets see, what happens if he drills into metal by accident, metal gets hot, goes into gas and: </TD></TR></TABLE>
gas itself isnt flammable - its the vapors, but i meant the top of the cap ( maybe i shouldve explained myself better ) not the sides ( but i agree - this should be the LAST thing that should be done - avoid this if possible )
Old Sep 21, 2007 | 08:54 PM
J.nguyen's Avatar
thanks for the advice , hopefully i can get it off w/o having to hack away at the cap
but first i need to find a gas cap to replace it with,
RSX gas cap same as S2k gas cap?
Old Sep 22, 2007 | 04:54 AM
m R g S r's Avatar
Default Re: how to remove broken gas cap? (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
Theirs a flap over the inlet, nothing will get in.</TD></TR></TABLE>
Where? I've seen one on all my cars except me S....maybe I'm blind thou
Old Sep 22, 2007 | 05:21 AM
Francesco's Avatar
Default Re: how to remove broken gas cap? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
Where? I've seen one on all my cars except me S....maybe I'm blind thou</TD></TR></TABLE>
Try to stick your finger in the gas tank, you have to depress a flap down to get in.
Old Sep 22, 2007 | 09:47 AM
GearShifter's Avatar
just buy a new s2k done and over with.
chitownrida
Jun 16, 2007 12:02 PM
Mik3
Jul 13, 2006 07:34 PM
deanh8
14
Dec 4, 2005 10:51 PM
^Sammy]!.
Aug 8, 2005 02:22 AM
killerboots
May 5, 2003 09:16 AM
