Honda S2000 Honda S2000
How does the push bottum start work?
Old Sep 16, 2004 | 05:28 PM
UA6 BALLER STATUS's Avatar
Default How does the push button start work?
Ive search but found nothing, can anyone please explain how the Honda s2000 pust button start works? TIA
Modified by Type SH at 6:55 PM 9/17/2004
Old Sep 16, 2004 | 05:54 PM
EMiranda's Avatar
Default Re: How does the push bottum start work? (Type SH)
push it
Old Sep 16, 2004 | 05:59 PM
Default Re: How does the push bottum start work? (Airman1038)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airman1038 &raquo;</TD></TR><TR><TD CLASS="quote">push it </TD></TR></TABLE>
Thats all? do you need to have the keys in the car? what if its in first gear, does it still start up? do you need to push in the clutch while pushing the button?
Old Sep 16, 2004 | 06:24 PM
Nishant's Avatar
keys in and clutch in, push start
EMiranda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type SH &raquo;</TD></TR><TR><TD CLASS="quote">
Thats all? do you need to have the keys in the car? what if its in first gear, does it still start up? do you need to push in the clutch while pushing the button? </TD></TR></TABLE>
iono bout the key's being in the ignition cuz i dun own a S2K but if it's in gear then it would b wise to have ur foot on the clutch. go ahead and try it and tell me wat happens
Old Sep 16, 2004 | 06:46 PM
Mr. Bagel's Avatar
it's just like any other car. key in, turn key, turn key to ingition point, it stops. it doesn't travel any further in order to engage the starter. once that is in place, you put in the clutch and hit the start button to start up the car (instead of turning the key a little more). the car will not start without the clutch being IN. I believe all new cars are required to have this safety measure put in.
Old Sep 16, 2004 | 09:13 PM
hypnosisracing's Avatar
Default Re: How does the push bottum start work? (Mr. Bagel)
Yup...key's gotta be in, clutch has gotta be pushed, button push and your ready to go.
BTW...On many german cars (mainly from the 90's) you DONT have to have the clutch engaged to start the car, just for your own knowledge.
Old Sep 16, 2004 | 09:17 PM
Default Re: How does the push bottum start work? (hypnosisracing)
Thanks guys for the info. Whats the point of a push button start? is it better in any way or what?
Old Sep 17, 2004 | 05:08 AM
dohcbag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type SH &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys for the info. Whats the point of a push button start? is it better in any way or what?</TD></TR></TABLE>
well my key gets a little funky in my ej coupe, so i guess its for key wear...
btw my car has 255800 miles so a little bit of key wear
Old Sep 17, 2004 | 05:09 AM
mistersparco's Avatar
washuuu
It's cool. Imagine telling a girl to "push the button to start him up".
Old Sep 17, 2004 | 08:34 PM
boostdd's Avatar
I got auto start so i don't need to press the clutch , its pretty coo, just don't ever leave it in gear, luckly i never do.
Old Sep 18, 2004 | 11:45 PM
steven975's Avatar
it fit with honda's design goal with Formula 1 influences.
Old Sep 19, 2004 | 12:04 AM
evil vapor's Avatar
adds 5hp to the wheels
Old Sep 19, 2004 | 12:51 AM
greenmonster's Avatar
Default Re: How does the push bottum start work? (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">
adds 5hp to the wheels</TD></TR></TABLE>
LOL hehe
Old Sep 19, 2004 | 11:30 AM
RallyRedGT-V6's Avatar
Default Re: How does the push bottum start work? (greenmonster)
nah..just for the cool factor...
i put a push start in the integra..my girl loved it, she used to beg to start the car...
then i got more ambitous and wired a toggle switch to act as an on/off switch, so flipping the switch was the same thing as putting the key in and turning it....so no more keys at all after that...'
luckily the alarms' starter disable still stopped it from starting when it was armed
Old Sep 21, 2004 | 06:01 PM
optikal_blitz's Avatar
Default Re: How does the push bottum start work? (96integra)
would you like to email me some instructions/wiring diagram on that toggle switch start? optikalblitz@hotmail.com.
Old Sep 24, 2004 | 09:07 AM
equinox18's Avatar
Default Re: How does the push button start work? (Type SH)
Push the Clutch in and while holding it down just simply press the push start. It's just like an ignition with a key, you have to hold the clutch then press.
Old Sep 24, 2004 | 10:04 AM
jolt-tsp's Avatar
Default Re: How does the push bottum start work? (NatakuBlitz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatakuBlitz &raquo;</TD></TR><TR><TD CLASS="quote">would you like to email me some instructions/wiring diagram on that toggle switch start? optikalblitz@hotmail.com.</TD></TR></TABLE>
Just open up your column. There's a wire connected to the main combination switch. It it soldered to the point labeled "ST" on most cars. Just run a wire off of that, to a momentary button, and ground the other side of the button. Be sure to match the wire guage that is use to the start switch on the combo switch (I beleive it is 14).
Edit: This will run the starter without the key in, but not without the clutch in. Obviously the engine will not start though without the key in though.
Old Sep 24, 2004 | 10:25 AM
So if'n i do that, it'll work the same way yours does (as described)?
If so, itd be nice to just be able to disarm my car with the remote and get in it and push the button.
Old Sep 24, 2004 | 12:34 PM
jolt-tsp's Avatar
Default Re: (NatakuBlitz)
I had my civic hooked up with 3 on/off switches and a momentary button. No key once you got in, and the switches were hidden. Worked pretty well The on off switches were wires from ACC -&gt; Ground, IG1 -&gt; Ground, IG2A -&gt; Ground, and the button from ST -&gt; Ground. These are normally labeled on the combination switch. I forget what color the wires were. This is on a civic, but it's the same for most Honda's.
If your car was 98+ I beleive, then the key needs to emit a certain RF frequency to start the car. I don't know how to get around that.
Old Sep 24, 2004 | 11:09 PM
92 Prelude here- and i'd be very surprised if that key could even emit the correct tumbler articulation. haha.
melsun_ap1
Honda S2000
38
Dec 4, 2007 12:21 AM
accordredliner
Honda S2000
Feb 20, 2006 10:57 AM
shakenbake2001
29
Sep 25, 2003 07:32 AM
StreetRacnGsR
May 18, 2003 03:49 PM
