Honda S2000 Honda S2000
Hardtop Install kit?
Old Aug 22, 2006 | 05:46 PM
nikboca's Avatar
Default Hardtop Install kit?
I have heard that some S2000 don't need the kit for the hardtop. Is this true? I am buying a hardtop tomorrow and my S is a 2000. Thanks.
Old Aug 22, 2006 | 06:49 PM
TRE_'s Avatar
Default Re: Hardtop Install kit? (nikboca)
How much you picking it up for?
and to answer your question , all of the s2k's need the MOUNTING hardware, which is the same for all years, only difference lies in the install instructions. the 00-01 models require an extra kit if you want to use the rear defrost, which is sold as a kit from honda. as i've mentioned in other threads that defrost kit is on backorder from honda and retails for around $350.
Old Aug 22, 2006 | 11:43 PM
Francesco's Avatar
put your top down, look behind your seats on the interior trim pannel with the brushes.
see the silver bracket with a hole in it? if not you need a hardtop kit
you probably need it. since your a 2000 you will need the kit A which comes with the rear window defroster harness and switch.
Old Aug 23, 2006 | 01:22 AM
itr-j's Avatar
Default Re: Hardtop Install kit? (Francesco)
http://www.hardtopguy.com he sells the kits.
Old Aug 24, 2006 | 03:25 PM
nikboca's Avatar
Default Re: Hardtop Install kit? (itr-j)
Does anyone know where I can just buy the brakets for the hardtop to hookup in the back. I don't need the defroster kit or anything else. The hardtop guy wants $400 for them. Its just two brakets they should be cheaper than that.
Thanks
ego_maniac
May 24, 2010 02:44 PM
1999CivicSi
Apr 5, 2008 12:41 PM
JDMVTEC
Feb 26, 2004 03:11 PM
RedTegLS
Oct 14, 2003 02:07 PM
