Honda S2000 Honda S2000
Hardtop Hardware question
Old Mar 10, 2007 | 07:30 PM
chinkieboy's Avatar
Default Hardtop Hardware question
i found a used 2005 OEM hardtop, the seller stated its with rear mounts and wiring harness for AP2, but i have an AP1, and now i'm not sure what hardware i need to purchase in order to install the 05 OEM hardtop. i tried to look at hardtopguys.com, but seems like they didn't list all the parts that included in the installation kits.
If anybody can list all the hardware i need that would be great.
-Thanks
Old Mar 11, 2007 | 01:53 PM
Cboi's Avatar
Default Re: Hardtop Hardware question (*****ieboy)
The wiring harness is a defroster plug, which should plug and play on 02-03 AP1s. If you have a 00-01 model, you would have to run the wiring yourself. Some hardtop catchers might be a good idea.
Old Mar 11, 2007 | 03:05 PM
chinkieboy's Avatar
if someone can give me a whole list of what i need that would be great also.
Old Mar 12, 2007 | 08:49 AM
18psi sohc's Avatar
Default Re: (*****ieboy)
If you have a honda dealership nearby you can just walk into the parts department and they'll hook you up. Or call up the cust serv for hardtopguy.
Old Mar 12, 2007 | 10:51 AM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****ieboy &raquo;</TD></TR><TR><TD CLASS="quote">if someone can give me a whole list of what i need that would be great also.</TD></TR></TABLE>
1) Rear mounts = side locks, which you already have.
2) Defroster plug should be hanging from the rear glass, that plugs into the car's defroster harness, found under the rear softtop tray. You can access it from the trunk, to the left of the spare tire, behind the driver seat.
3) Hardtop catchers.
Old Mar 12, 2007 | 11:10 AM
Francesco's Avatar
Hard top install kit A, B or C.
You need:
2 rear catchers.
2 front strakes
Rear defroster wiring harness
You might need:
Rear defroster switch for the center console with harness
toner297
Lighting
Apr 9, 2008 08:01 PM
Rzoops
Jan 27, 2006 06:51 AM
Robot Sonic
Mar 20, 2005 05:57 AM
Relick!
Oct 31, 2004 01:41 AM
BEN52
Audio / Security / Video
May 19, 2004 07:25 AM
