Honda S2000 Honda S2000
hard top conversion?
Old Aug 11, 2006 | 10:17 AM
  #26
EGHatch94's Avatar
Default Re: (Tyson)
no, francesco has a mugen hardtop, i think.
Old Aug 11, 2006 | 11:41 AM
  #27
Tyson's Avatar
Default Re: (EGHatch94)
$1650 for a mugen?
Old Aug 11, 2006 | 02:19 PM
  #28
EGHatch94's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by
Francesco
&raquo;
</TD></TR><TR><TD CLASS="quote">
Originally Posted by TomTomTuning
I wanted to get my Hardtop first, but i think the Diffuser might be on the top of my list.
I think i will just get the OEM hardtop
dont you have a mugen top? </TD></TR></TABLE>
mugen hardtop
https://honda-tech.com/zero...ge=90
Old Aug 18, 2006 | 02:50 PM
  #29
CHILIBEANZ's Avatar
Default Re: (tk2068)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tk2068 &raquo;</TD></TR><TR><TD CLASS="quote">How long would it take to remove the entire convertible assembly for a novice? Was there any special tool needed? Thanks.</TD></TR></TABLE>
sorry it took a sec to reply but it's not worth the time if you don't plan on racing. it took me about 12 hours with basic tools and no helm's manual. the hardest thing is getting to all of the bolts and pins for the panels. keep the rag top with it for easy on and off.
Old Aug 18, 2006 | 04:29 PM
  #30
Will_ChinLee's Avatar
I'll have to add my .02cents. having owned an OEM and currently owning a CF Seibon hardtop. the install very quick and easy. Took me about 30mins to fully install the OEM and about 5mins to install the CF. I personally never liked the fact that the S2000 was a vert.
The oem is quality, but the CF is ****.
Old Aug 18, 2006 | 08:27 PM
  #31
TRE_'s Avatar
Default Re: (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">unless you buy your hardtop from i think it was Flagstaff Arizona Honda for $2800 or something like that</TD></TR></TABLE>
$2800 is correct, did them at $2700 shipped for a while but the cost of freight has come up.
We've done about 4 at my dealership and they arent terribly difficult, the instructions are very complete and descriptive, although like others have mentioned getting it aligned perfectly takes a little bit of time. Just FYI hardware is the SAME for all years, only difference is the instructions. Also the 00-01 S2k's require an extra hardware kit if you wish to have the rear defogger($350 extra and still on backorder from Honda ), if anyone needs help PM me
Old Aug 18, 2006 | 10:17 PM
  #32
2camsaam's Avatar
Default Re: (Will_ChinLee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Will_ChinLee &raquo;</TD></TR><TR><TD CLASS="quote">I'll have to add my .02cents. having owned an OEM and currently owning a CF Seibon hardtop. the install very quick and easy. Took me about 30mins to fully install the OEM and about 5mins to install the CF. I personally never liked the fact that the S2000 was a vert.
The oem is quality, but the CF is ****. </TD></TR></TABLE>
Assuming that since **** are great, the CF hardtop is better than OEM (I am unsure of the meaning of **** in this instance)? Do you feel this way for both fitment and or design?
Old Aug 18, 2006 | 10:22 PM
  #33
2camsaam's Avatar
Default Re: experience in installing a hardtop (tk2068)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tk2068 &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a hardtop two weeks ago and installed it myself. Transporting the hardtop home is a pain since the box is huge (5.5' x 5' x 2') even though it weighs only about 120lbs. So pay somebody to deliver it to your doorstep.
Installation is very easy since the instruction is very clear and the steps involved are simple (if you know how to use a screwdriver, a ratchet, and are unafraid to pull things apart). For somebody who is mechanically-challenged like me, it took me a total of four hours to install.
To me, the most difficult step is to adjust the retainers since I had to hunt those wind noise but my cabin is pretty quiet now. I guess it could have been worse since I have read people complained about having to replace their front strikers due to wind noise so I feel pretty lucky.
The next most difficult step is, like someone mentioned earlier, is to align the the hardtop for the initial install. It is a pain because one has to loosen a total of 8 bolts, seats the hardtop, tighten the bolts, and repeating these steps until the hardtop is aligned properly. The cabin is small so moving around just get that much more difficult.
Now I can take off and put on my hardtop in about five minutes. I have done it a few times. Need two people or you will scratch your paint or worse.
You say your hardtop weighs 120lbs., someone earlier stated that theirs weighed 42lbs.
Is the one that is 120lbs. OEM and the one that is 42lbs. CF?
Old Aug 19, 2006 | 08:51 AM
  #34
soldiaboy's Avatar
I think he meant the box weights 120
Old Aug 19, 2006 | 11:00 AM
  #35
tk2068's Avatar
Default Re: experience in installing a hardtop (2camsaam)
Yes, the hardtop itself is probably 42-44lbs (never weighed it) but the packaging material is first class. Have never seen thicker/stronger/heavier cardboard packaging material. It was quite hard to dispose of.
Old Aug 19, 2006 | 04:12 PM
  #36
alexS2000fan's Avatar
so where can i find some hardware for my soft top cause one of the lock for my soft top is broke. how much are they and how much would it cost to get it done at the honda dealer?
Old Aug 20, 2006 | 04:36 PM
  #37
J_Marc's Avatar
What is the inside of the hardtop like? Does it have a headliner, or is it painted?
Old Aug 20, 2006 | 05:04 PM
  #38
Francesco's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
thats for used oem hardtop right?
what have ppl paid for a used mugen frp one?</TD></TR></TABLE>
yes that was for OEM.
I will sell my FRP Mugen for 2,800$. Yes it may sound like much, but theirs no wait and its berlina. If someone gave me 2,800 for it I woud go Mooncraft.
Old Aug 20, 2006 | 05:47 PM
  #39
Tyson's Avatar
Default Re: (Francesco)
are you in socal?
Old Aug 20, 2006 | 06:38 PM
  #40
Francesco's Avatar
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">are you in socal?</TD></TR></TABLE>
Im east coast, but I wish I was out West.
Old Aug 22, 2006 | 01:44 PM
  #41
CHILIBEANZ's Avatar
Default Re: (alexS2000fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexS2000fan &raquo;</TD></TR><TR><TD CLASS="quote">so where can i find some hardware for my soft top cause one of the lock for my soft top is broke. how much are they and how much would it cost to get it done at the honda dealer?</TD></TR></TABLE>
handaaccessories.com
not sure on price but easy enough to do it yourself.
Old Aug 22, 2006 | 01:45 PM
  #42
CHILIBEANZ's Avatar
Default Re: (J_Marc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_Marc &raquo;</TD></TR><TR><TD CLASS="quote">What is the inside of the hardtop like? Does it have a headliner, or is it painted? </TD></TR></TABLE>
headliner, and it's very nice
Old Aug 22, 2006 | 09:21 PM
  #43
tk2068's Avatar
In case you still want to know what the interior of the hardtop looks like, here it is.
Old Aug 22, 2006 | 11:38 PM
  #44
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tk2068 &raquo;</TD></TR><TR><TD CLASS="quote">In case you still want to know what the interior of the hardtop looks like, here it is.
thats OEM though.
Old Aug 23, 2006 | 08:53 AM
  #45
Tyson's Avatar
i gotta admit, that is pretty nice looking to have fully upholstered and matching underneath.
Old Aug 23, 2006 | 03:23 PM
  #46
Urban Camo's Avatar
Default Re: (Tyson)
what does the inside of a mugen one look like?
Old Aug 25, 2006 | 07:09 AM
  #47
lucky13AP2's Avatar
Default Re: (Urban Camo)
i blieve the Mugen one doesnt have a vynal in it, if your getting the fiber glass one er the Carbon fiber one i believe its jus bare.
Old Aug 25, 2006 | 10:56 AM
  #48
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Urban Camo &raquo;</TD></TR><TR><TD CLASS="quote">what does the inside of a mugen one look like?</TD></TR></TABLE>
its just raw black fiberglass. i had mine painted satin black
Old Aug 26, 2006 | 05:54 AM
  #49
Urban Camo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
its just raw black fiberglass. i had mine painted satin black </TD></TR></TABLE>
I will probably do the same, does it make your exhaust resonate not having any headliner?
Modified by Urban Camo at 7:08 PM 8/26/2006
Old Aug 26, 2006 | 10:57 PM
  #50
teknoracing's Avatar
Default Re: (Tyson)
mugen hardtop FTW!!!!!!!
