Honda S2000 Honda S2000
grinding in third
Old Oct 3, 2005 | 01:06 PM
scs2000622's Avatar
Default grinding in third
i have 60000 miles and when i go in to third i grind all the way it. this only happens when i am driving hard. i think its a synchronizer, but i dont know if the fluid has been changed, is it possible that this is it. im hoping thats what it is so i dont have to give my car up for a day to a shop. thanks
Old Oct 3, 2005 | 01:23 PM
Almostlude's Avatar
If your syncros are shot, then a fluid change will not correct a bad syncro, but try to change the trans fluid and use a good quality brand, if you're unsure of which brand to use, just go HondaMTF. I've heard people using GM Syncromesh, Redline, and/or a combination of that plus HondaMTF. Good luck bro.
Old Oct 3, 2005 | 02:12 PM
ken-e's Avatar
Default Re: (Almostlude)
I once had a bad 3rd gear grind in a civic. I changed the fluid to gm syncromesh and it went away
Old Oct 3, 2005 | 02:25 PM
WowOzYouRock's Avatar
Default Re: (ken-e)
^^ gm syncromesh is like pepto bismol ... tranny is the achy stomach, and once you put the pepto bismol it'll fade away ROTFLMAO
selfmade0086
Transmission & Drivetrain
Jun 3, 2013 07:12 PM
Ilovemydc5integra
Mar 10, 2008 07:06 PM
redline32
Nov 27, 2007 04:33 AM
rotagt3R
Aug 19, 2006 04:49 PM
aquabob89
Jan 30, 2006 03:37 PM
