Honda S2000 Honda S2000
gases
Old Aug 26, 2004 | 10:39 PM
JKS2000's Avatar
Default gases
what gas is the best 76, chevron, shell?
Old Aug 27, 2004 | 08:03 AM
SuzukaBlueAP2's Avatar
Default Re: gases (JKS2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKS2000 &raquo;</TD></TR><TR><TD CLASS="quote">what gas is the best 76, chevron, shell?</TD></TR></TABLE>
55 gal drum of ethanol
It's only about $5.00/gallon right now
Old Aug 27, 2004 | 08:05 AM
Ferrell's Avatar
Default Re: gases (ScreaminTeg)
nitromethane
Old Aug 27, 2004 | 12:35 PM
Formula 1's Avatar
Default Re: gases (Ferrell)
i heard shell is crappy(watered down, leaves soapy residue in your tank and corrodes injectors) I know Ferrari uses Shell for Forumla 1, but that has to be specially designed for the motors. Whatever I use chevron mostly. 92 octance
Old Aug 27, 2004 | 05:32 PM
Razor's Avatar
Default Re: gases (SikCivic)
chevron
Old Aug 27, 2004 | 10:30 PM
SimbaDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">55 gal drum of ethanol
It's only about $5.00/gallon right now</TD></TR></TABLE>
this actually brings up a question i had. i was reading about brazilian cars that can run on alcohol or gasoline in any 100:0 or 0:100 ratio. And i was just wondering about ethanol, and how safe it would be to run in a car that isn't really configured to be ran with it. I believe i've heard of some people running ethanol/methanol in their cars as an addictive...gives you octance levels on the likes of c14/c16....but i heard that the shiet isn't reeally great for a cat if you're still running one. someone wanna break down the do's and donts of fuel mixtures?
Old Aug 28, 2004 | 07:23 AM
Rodrigo's Avatar
Between those three, I'd say Chevron.
Old Aug 28, 2004 | 07:32 AM
VTECorona's Avatar
Default Re: (mr2jzgte)
I'm personally a sunoco fan, chevron is good too.
Old Aug 28, 2004 | 10:15 AM
Razor's Avatar
Default Re: (VTECorona)
stay away from shell
Old Aug 28, 2004 | 10:35 AM
Default Re: gases (SimbaDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg &raquo;</TD></TR><TR><TD CLASS="quote">
this actually brings up a question i had. i was reading about brazilian cars that can run on alcohol or gasoline in any 100:0 or 0:100 ratio. And i was just wondering about ethanol, and how safe it would be to run in a car that isn't really configured to be ran with it. I believe i've heard of some people running ethanol/methanol in their cars as an addictive...gives you octance levels on the likes of c14/c16....but i heard that the shiet isn't reeally great for a cat if you're still running one. someone wanna break down the do's and donts of fuel mixtures?</TD></TR></TABLE>
You know, I've never talked to anyone that has run it on the street. THe only guys I know that run it are running it in small block and big block sprint cars. They did, however, tell me that when they'd run it instead of the leaded turbo blue, the cars run MUCH cooler.
I dunno what it would do really in our engines..
Old Aug 28, 2004 | 10:54 AM
SimbaDogg's Avatar
well, if they're running it instead of a leaded gasoline, i couldn't imagine that i'd be any good. leaded gasoline, great lubrication...but doesnt like the stock cat much. any physics/chemical engineering guys in here?
Old Aug 28, 2004 | 12:57 PM
evil vapor's Avatar
they're all the same
SIXPAK GQ
Jul 19, 2007 04:55 PM
hbgrom
Honda Civic (2006 - 2015)
19
Aug 31, 2006 06:33 AM
cyang08
Mar 13, 2006 09:21 AM
spoonef
Jun 25, 2005 06:13 AM
RCautoworks
Welding / Fabrication
10
Oct 6, 2004 05:47 AM
